Nous sommes actuellement le 12 Mai 2026, 08:58
HxC Floppy Emulator
Publier un nouveau sujet Répondre au sujet  Page 33 sur 50
 [ 742 message(s) ]  Aller vers la page Précédent  1 ... 30, 31, 32, 33, 34, 35, 36 ... 50  Suivant
guyome
Message Publié : 27 Avr 2015, 15:55
Message(s) : 161
http://www.leboncoin.fr/informatique/79 ... tm?ca=12_s
:mdr:
Jeff_HxC2001
Message Publié : 28 Avr 2015, 22:23
Message(s) : 269
-----------H----H--X----X-----CCCCC----22222----0000-----0000------11----------
----------H----H----X-X-----C--------------2---0----0---0----0--1--1-----------
---------HHHHHH-----X------C----------22222---0----0---0----0-----1------------
--------H----H----X--X----C----------2-------0----0---0----0-----1-------------
-------H----H---X-----X---CCCCC-----222222----0000-----0000----1111------------
--------------------------------------------------------- http://hxc2001.com --
HxC Floppy Emulator project
(c) 2006-2015 Jean-François DEL NERO / (c) HxC2001
STM32 Based hardware bootloader Downloader and Flasher.
This software allows you to download and program the STM32 HxC bootloader into
a STM32 based floppy emulator hardware. (For example these "Gotek" or the next STM32 HxC Floppy emulator units).
Note : This Flash procedure should be needed only once per device since the STM32 HxC bootloader
       will allows you to update the device with a simple USB stick.
To use it you need :
-> A STM32 based floppy emulator hardware to flash.
-> A PC under Windows connected to Internet.
-> Any 3.3V serial connection to connect the Floppy Emulator hardware to the PC.
-> Your account information. Contact me to hxc2001()hxc2001.com to get your account.
To Flash the device :
-> Set the BOOT0 signal to the VCC3V3 on the device. (Add a connection between "J3" and the VCC3V3 pin. See below).
-> Connect your serial adapter to the device and to the PC. (GND,RX,TX,+5V)
   Note 1: To power the device, you can use a external +5V source or the +5V coming from your USB adapter.
   Note 2: Cross connect your serial adapter to the device : TX wire to the RX pin, RX wire to the TX pin.
-> Start the SecSerialBridge software and select the COM port of your serial adapter. Click on the button "Open"
-> Enter the server and your contacts data. Click on the button "Connect".
   If the connection to the server succeed you will get the "Link is UP !" status.
-> Some seconds later you should get the "Device detected." status.
   Note : If you don't get it, try to reset the STM32 by making a short connection of the reset signal (RST) to GND.
-> Once the device is detected, you can press the "Program" button.
   The download and programming process finish with a "Done !" Status. The whole process take some minutes.
Once done, remove all the connections previously done on the programming pins.
The device should now display "Ldr" at power up and wait for a USB flash drive with a UPD file to use.
You can download these files on the HxC website.
|       Programming connector       |
The Programming connector is near the power input connector. (SFRC922,SFRC526,...)
-+--- NC
-+--- GND      O J3 (BOOT0)
-+--- GND      O VCC3V3
-+--- +5V     OO TX
 |        +5V OO RX
 |        GND OO RST
05/28/2015
http://hxc2001.free.fr/floppy_drive_emu ... l#download
http://hxc2001.com/download/floppy_driv ... Bridge.zip
http://hxc2001.com/download/floppy_driv ... 0_0_0a.zip
Bref, Les personnes équipées d'un de ces émulateurs et ayant l'adaptateur série, contactez moi via email pour une session de test grandeur nature :)
guyome
Message Publié : 29 Avr 2015, 13:37
Message(s) : 161
@Jeff_HxC2001
Ca concerne uniquement les personnes qui ont deja un Gotek alors ?
Et pour ceux qui n'ont pas encore la machine tu conseille quoi ?
Message Publié : 29 Avr 2015, 18:33
Mail sent !
Message Publié : 01 Mai 2015, 08:42
Gotek flashé, firmware updaté: les premiers essais sont concluants !
Merci Jeff pour ce boulot trés pro ! :)
Message Publié : 01 Mai 2015, 10:17
gotek flasher également
cela marche nickel :winner:
juste un probleme ...
quand je renome un hfe en AUTOBOOT.hfe aucun probleme je peux lancer le jeu
par contre si je lance hxc de son autoboot, sur ma cle usb 512mo j'ai hxcerror_attachmediafailed et sur une cle 32go j'ai le blocage dans la lecture du fichier de config
les deux cles fonctionnent en mettant un hfe renomme en autoboot.hfe
Jeff_HxC2001
Message Publié : 01 Mai 2015, 10:52
Message(s) : 269
Un nouveau firmware (UPD) est dispo sur le site :
Je pense que cela va corriger le problème.
Jeff_HxC2001
Message Publié : 01 Mai 2015, 11:09
Message(s) : 269
Question a ceux qui ont utilisé le flasher en ligne: Vous avez utilisez quoi comme adaptateur série ? (modèle exact si possible)
guyome
Message Publié : 01 Mai 2015, 11:18
Message(s) : 161
@Kris @breiztiger
Vous avez quoi comme modèle les gars ? :o
Message Publié : 01 Mai 2015, 11:36
J'ai flashé un SFRC922 sans pb.
Message Publié : 01 Mai 2015, 11:51
idem pour moi SFRC922 avec un prolofic PL-2303 XA / HXA
note : avec le 3.0.0.1a plus le message d'erreur sur la cle Kingston 512mo mais bloque au fichier de config, sur la 32go tout marche nickel maintenant :biere:
fb29
Message Publié : 01 Mai 2015, 11:53
Message(s) : 1
Silicon labs CP210x2USB UART Bridge acheté sur Ebay environ 5 euros
Jeff_HxC2001
Message Publié : 01 Mai 2015, 11:57
Message(s) : 269
Ah oui forcement : L’émulateur supporte la FAT complétement (FAT32, FAT16, FAT12...), mais les softs CPC sont "limités" a la FAT32. Donc il faut formater la 512mo en FAT32 ;)
Message Publié : 01 Mai 2015, 13:17
merci beaucoup
cela marche avec la cle 512mo en fat32
super boulot !!!
manque plus que le support des dsk :D
Message Publié : 01 Mai 2015, 13:18
merci beaucoup
super boulot !!!
+1 :D
