Nous sommes actuellement le 01 Juil 2026, 09:53
iMPDraw
 [ 64 message(s) ]  Aller vers la page 1, 2, 3, 4, 5  Suivant
 Sujet du message : iMPDraw
Message Publié : 17 Déc 2014, 08:00
Message(s) : 5139
AST/iMPACT vient de sortir la preview de son nouvel utilitaire de dessin:
Here comes my new project started on the 12/12/14. For the history, I was trying some testkey routines and I decided to start the coding of a new Paint Project, and "iMPdraw" was Born, my first fullscreen Cpc Paint.
For now, you'll only see a Preview just to test it and give me a feedback. Love it or not ?
This tool could be used on Cpc Plus and Cpc Old. It's programmed on Cpc Plus, so i know all splitscreen Will have to be modified to work properly.
For now, only Cpc Old version is really started but Cpc Plus version works correctly in Cpc Old mode.
Cpc Plus version (with Plus featuring) will come after, because there' s no fullscreen paint on Cpc Old. If you want to use Cpc Plus features, please use "Graph'Os" from BdcIron.
Of course many features as loading, saving, size of screen, mode screen selection and so on are missing. Just wait for the final version.
How to USE this tool ?
A (Azerty Keyboard for the moment) INK+
Z (Azerty Keybord for the moment) INK-
Arrow -> use to move the cursor on the screen (the cross to display the position on the screen is missing)
DEL -> Use it to delete last pixel and so on.
Space -> When the correct ink is selected, use arrow to move and Space to write pixels on your screen
1 -> When you have selected your ink, you must choose between 26 pens for each ink
(ink - 26 to 0 still bugged)
2 -> When you have selected your ink, you must choose between 26 pens for each ink
(ink + 0 to 26 works correctly)
That's All for today ! As I told you, i'm waiting for your feedback...
src: http://amstradplus.forumforever.com/t43 ... -v1-0f.htm
file: https://www.sendspace.com/file/kntxbo
 Sujet du message : Re: iMPDraw
Message Publié : 17 Déc 2014, 10:54
Merci d'avoir relayé l'info. Donnez moi votre avis....
Subaru
Message Publié : 17 Déc 2014, 11:15
Message(s) : 475
Encore une bonne news. :goodpost:
Etant une bille en angliche, j'irais zieuter ça, aprés m'être inscrite sur ton fofo, AsT. ; )
J'ai un p'tit truc dans un coin de ma tête, et ce log pourrait bien m'être trés utile. ^^
Message Publié : 17 Déc 2014, 11:38
C'est fait ma grande....
Subaru
Message Publié : 17 Déc 2014, 11:43
Message(s) : 475
Message Publié : 17 Déc 2014, 11:55
Je viens juste de te traduire la fonction des touches... Au cas où.... Donne moi ton avis, les faiblesse, les axes de progrès... Etc...
Subaru
Message Publié : 17 Déc 2014, 12:00
Message(s) : 475
Oki. /thx. ; )
Je regarderais aprés manger sur un autre émul car là, CPCE reste sur un écran bleu, aprés lecture du .sna. Image
Message Publié : 17 Déc 2014, 12:01
C'est normal, le .sna est compressé. Lis le sur winape.
Bon appétit.
Message Publié : 17 Déc 2014, 12:56
Ou utilise un SNA non compressé, pour éviter de devoir utiliser WinAPE. :)
Message Publié : 17 Déc 2014, 13:10
Sauf que j'ai fait le .sna sur winape :oops: Désolé :sweatingbullets:
Message Publié : 17 Déc 2014, 13:14
Quand tu fais un SNA avec WinAPE, tu as le choix de compresser ou pas dans la fenêtre de sauvegarde.
Message Publié : 17 Déc 2014, 13:20
Merci pour cette info... En plus, je le savais... Faute d'inattention, sûrement du à mon impatience de présenter le projet. Raaaahhhhh....
La version Dsk est dispo sur le forum.
Message Publié : 17 Déc 2014, 14:59
Message(s) : 5139
peut-être déplacer la barre du haut au niveau de la séparation écran normal/zoom pour plus de clarté ...
* une grid sur la partie zoomé saurai pas de refus, un curseur clignotant aussi ..
* load (scr/sca/win/et le format demoniak),
* une fonction save :cow:
* un cut/copy de portion(s) d'écran,
.. encore beaucoup de chose a codé David, bon courage !!!
Message Publié : 17 Déc 2014, 15:49
En gros, ce sur quoi je suis en train de bosser :mdr:
Par contre, la grille, je ne suis pas convaincu....
T'as testé sur emul ou Cpc? Si cpc, quel crtc? J'ai besoin de savoir sur lequel je devrais reprogrammer mes ruptures... Merci d'avance...
Crtc 3: ok
Crtc 4 : ok
Subaru
Message Publié : 17 Déc 2014, 16:15
Message(s) : 475
Testé sur winape. Sympa comme truc. :)
Ca m'a fait penser à stradgraf. :D
J'irais récup le dsk ce soir, et je ferais un test "réel" sur CRTC1, si ça peut aider.
