Nous sommes actuellement le 18 Août 2026, 23:37
Publier un nouveau sujet Répondre au sujet  Page 2 sur 16
 [ 235 message(s) ]  Aller vers la page Précédent  1, 2, 3, 4, 5 ... 16  Suivant
Message Publié : 31 Jan 2014, 07:19
Super ! Merci du retour !
Message Publié : 01 Mars 2014, 21:38
Voici donc une nouvelle version de mon émulateur... v0.17 donc !
Pas d'énormes changement sur le fond de l'émulation sur celle-ci, je me suis plutôt concentré sur des aspects plus pratiques.
Voici le lien : http://sugarbox.free.fr/?p=55&preview=true
Voici le log :
- Gate array : MMR Corrected : If a 128k config is set, only 128k are available.
- Gate array : Corrected access to MMR and MMR through PAL
- Gate array : Mode 3 is handled
- Monitor : Change the function used for adjustement on HSync : Use a square root instead of a log, to make some demos more stable ("Camembert 4" demo for example)
- Timings : Adjust some timings for out command. "From scratch" demo now display correct colours at the correct place
- FDC : Reset is (really) fixed. It no longer set the FDC in a state that prevent it to be used
- FDC : Add delay during track change
- General : Load the Xinput lib in the code, to avoir non runing app on some XP systems.
- General : Screenshot option added
- General : Speed limit is more configurable, from 50% to no-limit
- General : Some code optimisations
- General : Screen size can change (from "full PAL display" to "standard CPC screen")
- General : Directories problems have been solved. It is now possible to drag'n'drop dsk file to a sugarbox shortcut (or to associate dsk with sugarbox)
- Sound : Volume slider added
- Sound : Mute option added
- Sound : Record is flushed, so the file is not only written at the end of the recording
- GUI : Current track number is displayed
- GUI : Add a "scanline" option
- GUI : Add nice icon for sound and disks
- GUI : Added Screenshot, settings and reset icons
- Startup : Associating "dsk" with sugarbox offer the possibilitty to load disk directly
Message Publié : 26 Mars 2014, 21:50
Nouvelle version disponible (v0.18).
Au programme, quelques corrections sur le CRTC 1 (toujours) qui fait tourner la majorité des démos, et quelques corrections de bug genants (sur les chemins et les config, entre autre, ou sur un plantage qui pouvait arriver lorsque l'on quittait l'émulateur).
Support des SNA aussi, ce qui est bien pratique pour debugger.....
La version se trouve ici :
http://sugarbox.free.fr/?p=60
Subaru
Message Publié : 13 Juin 2014, 18:28
Message(s) : 475
Petit "problême" pour effacer. Les touches DEL et CLR sont inversées. Mais bon, on peut corriger ça dans le setup (F1). :)
Le clavier azerty répond aussi bien que celui de CPCE. Great ! :D
Bonne idée d'avoir mis COPY sur la touche ALT. C'est le seul truc qui me "gêne" sur CPCE.
Sinon, perso, chuis pas arrivée à entrer dans le drive B. Image
Dommage que le support "cassette" ne soit pas dispo. :(
Mais dans l'ensemble, GG Image.
Message Publié : 13 Juin 2014, 19:45
le positionnement de clr et del sont les meme que retour arriere et suppr sur nos claviers pc donc logique pour moi
le drive b: arrive complet dans la prochaine version, patience
plein de corrections de bug :mdr:
et surtout un fdc proche du sans faute :eng:
la cassette ... thomas un mot a dire ?
:biere:
Subaru
Message Publié : 13 Juin 2014, 20:02
Message(s) : 475
Justement non. Image
DEL = Delete (retour arrière) et CLR=Supp.
Or sur l'émul, c'est l'inverse. Donc, pas logique. Image
Message Publié : 13 Juin 2014, 21:08
Le gros du boulot depuis cette version porte effectivement sur le support FDC (avec une émulation précise du déplacement de la piste ). Une release ne devrait pas tarder, une fois que j'aurais fait un peu de nettoyage.
Le support cassette est prévu dans ma todo list, mais vu la longueur de celle-ci.... (support du cpc+, des crtc 0, 2, 3 ,4, de plein de feature demandés par mes beta testeurs (ils le méritent bien !), refonte du système de settings, etc....)
Note bien que j'inscris la dedans toutes les idées et remarques que je peux voir a droite à gauche !
DEL et CLR ont été positionné comme sur le clavier du CPC (je suis d'accord, ça n'est pas comme sur un clavier PC).
Subaru
Message Publié : 13 Juin 2014, 21:55
Message(s) : 475
Bah en fait, les claviers PC ne ressemblent pas tous. Mais la fonction de leurs touches, si.
D'instinct, pour un backspace, on appuyera sur la touche prévue pour (grande touche Delete) et non sur une des touche "Suppr".
Idem pour un CLR, on appuyera sur la touche Suppr, ça me paraît logique. Image
Mais bon, c'est vous qui voyez.
Dommage, également, que seul le mode CTM soit dispo.
Message Publié : 13 Juin 2014, 22:23
lone et moi parlons de position physique pas de ce qui est inscrit sur la touche
cela "tombe" au meme endroit sous les doigts sur le clavier pc comme cpc (a part le decalage sur le clavier pc bien sur)
veux tu un emulateur qui a tout mais moyen partout ou un avec des fonctions qui arrivent petit a petit mais pleinement fonctionnelle a chaque fois ?
cela fait un bout de temps que le fdc est en chantier mais la lone atteint bientôt la perfection :P
par exemple discology se lance depuis mon dump de l'original et surtout fait une exploration de lui meme correct (enfin idem le vrai cpc, parce que cela ne donne pas par exemple le rendu des secteurs taille 6 piste 2 et 3) c'est je pense le seul a le faire (un seul que je n'ai pas encore teste dans sa derniere version est ACE, desole philippe :kissed: )
Subaru
Message Publié : 13 Juin 2014, 22:43
Message(s) : 475
Positions physiques qui ne s'appliquent pas à tous les claviers PC.
La touche "àç$" est déportée sur la gauche d'un clavier PC (<>) alors qu'elle est à l'extrème droite d'un CPC... :?
Bref, passons.
Je ne faisais qu'apporter mon humble avis d'ex-utilisatrice de CPC, réduite à l'émulation.
Message Publié : 14 Juin 2014, 07:14
Le top serait d'avoir un clavier CPC en usb :kissed:
Message Publié : 14 Juin 2014, 07:24
En attendant, en AZERTY, les touches sont toujours inaccessibles sur WinAPE.
(enfin, si quelqu'un utilise encore cet émulateur pour faire autre chose que développer)
Message Publié : 14 Juin 2014, 08:50
Bref, passons.
Ne t'y trompe pas, tes retours m'intéressent beaucoup ( mon nombre d'utilisateur n'étant pas forcément très important, je prends en compte tous les retours que j'ai)
Au final c'est surtout une question de goût personnels et de possibilités de placement des touches : le clavier Pc n'a pas assez de touche à droite pour mettre la touche àç$.....
Subaru
Message Publié : 14 Juin 2014, 13:45
Message(s) : 475
J'avoue que le clavier de WinApe est un horreur. C'est pour ça que je préfère WinCPC et CPCE, bien que le mode monochrome de ce dernier, ne soit pas un "vrai" monochrome.
J'ai bien compris, ne t'en fais pas. Image
C'est bien pour ça que j'ai mentionné qu'un coup de F1, correction des deux touches et Rulezzz. :D
Message Publié : 23 Juin 2014, 22:26
Oui j'ai remarqué ça aussi, et c'est pas du tout naturel. J'espère que Thomas le corrigera en natif dans sa prochaine mouture de sugarbox :)
