Arcade Game Designer is a tool for writing your own simple arcade games. While it won't help you create snazzy scrolling shoot-em-ups, it should be capable of producing a variety of basic arcade affairs, puzzlers and platformers so long as you're patient and prepared to stick at it. That is, of course, provided that AGD does not crash horribly or something. Games produced using the utility are stand-alone and can be distributed freely.
v1.2: I've fixed a bug in the object initialisation code in the game engine so it should now be possible to place objects on any screen.
pas grave !!ça fait 10 ans que j'ai ce pseudo sur differents forum, je ne vais pas changer maintenant. mais c'est pas courant de tomber sur qqun qui connait le personnage.
sinon pour en revenir au tutaux , qqun a deja essayer?
news v1.3 (08.11.2013) - fixed sprite corruption at right edge of screen - return to BASIC at end of game - check for objects at next sprite position, not last position - sprites can now be spawned safely in main loop events - joystick 0/1 now selectable
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 47 invité(s)
