Nous sommes actuellement le 15 Août 2026, 23:23
[TOOL] SAMDisk - Nouvelle version
 [ 73 message(s) ]  Aller vers la page Précédent  1, 2, 3, 4, 5  Suivant
 Sujet du message : Re: [TOOL] SAMDisk - Nouvelle version
Message Publié : 20 Mai 2013, 08:45
salut a tous
Version 3.6 (2013-05-19)
- Improved gap extraction for floppy, IPF, and DMK sources
- Improved track length and sector positions using track data
- Added warning if FDC refuses to read sectors (128-byte MFM)
- Added minor EDSK extension for exact-multiple gap data sizes
- Added CRC16 support to existing 6K sector checksum tests
- Added detection of unwanted duplicate sectors in bad disk dumps
- Added support for 1MB TRD and SCL images
- Added --trim option to write only used sectors to TRD images
- Added --no-data for data privacy during disk diagnostics
- Fixed wrong location of rate/encoding extension in EDSK header
- Fixed SCL input having cyl/head reversed, so file data was wrong
- Fixed modification effects being applied to merge target on read
- Fixed image gap3 not being preserved during floppy writing
- Fixed false CRC warning in gap data of deleted sectors
- Fixed false FDC corruption when all track CHRN values were 0
- Changed SCL input CRC fatal error to a warning
- Changed to require --fix to missing weak sectors and gap CRCs
- Changed to ignore no-id and id-crc sectors from IPF and DMK
nouvelle gestion des gaps qui permet de selectionner automatiquement ceux a garder (--clean-gaps)
Message Publié : 23 Mai 2013, 19:37
update du 22 mai
Version 3.6.1 (2013-05-22)
- Fixed gap3 override issue during conversion of --all-gaps images
url/src: http://simonowen.com/samdisk/ ;linked:
Message Publié : 26 Juin 2013, 08:57
Version 3.7 (2013-06-24)
- Added support for KryoFlux and DiscFerret stream images (MFM+FM)
- Added preliminary support for D4M (FD-4000) disk images
- Added hex output with --hex or -x, with limited hex using --hex-ish
- Added --no-gap4b to ignore gap data after the final sector
- Added --abs-offsets to show absolute rather than relative sector offsets
- Fixed 'extra byte' EDSK extension being used unnecessarily on CRC errors
- Fixed crash during CPC weak sector sniffing due to no-data 4th sector
- Fixed regular image reading reporting transient disk errors
- Improved support for ED images, including 2.88M raw images
- Improved gap reading support for IPF images
- Changed raw track parsing to ignore headers with ID CRC errors
- Changed raw image writing to use only first cyl to determine format
- Relaxed D2M sniffing by removing system partition type (0xff) check
- Reduced gap sync requirement to remove more unwanted gaps
Message Publié : 26 Juin 2013, 18:55
Le support kryoflux n'est uniquement disponible que sur Mac OSX et LINUX. La version windows ne gère pas le format.
je cite :
"The following versions support disk images, but not floppy devices. However, disk imaging is still possible using a KryoFlux or DiscFerret device, using SAMdisk to convert the output.
samdisk-37-osx.zip — Mac OS X 10.5+
samdisk-37-linux-i386.zip — GNU/Linux i386"
je vais faire du lobbying pour que Simon Owen implémente les routines de Keir Fraser sur la version windows.......
Message Publié : 26 Juin 2013, 20:23
salut
desole de te contredire denis mais la conversion des dumps kryoflux raw est parfaitement fonctionnelle ;-)
j'en sais quelque chose pour en avoir fait pas mal pour simon :mdr:
Message Publié : 26 Juin 2013, 21:03
uniquement sur mac OSX et linux comme c'est indiqué sur le site de Simon.
je n'utilise ni mac OSX ni linux mais windows.
Message Publié : 26 Juin 2013, 21:39
idem pour moi seulement Windows :mdr:
donc cela fonctionne sous Windows comme déjà dit
edit : juste faire samdisk track00.0.raw disk.dsk dans le repertoire ou tu as les track00.0.raw a track42.0.raw
Message Publié : 26 Juin 2013, 22:06
Mais merci pour le tuyau, je vais l'appliquer de ce pas sur mes dumps kryoflux :)
Désolé, mais je viens d'essayer, et ta manip elle fonctionne absolument pas. J'utilise Samdisk 3.7, la dernière release pour windows......
Donc en fin de compte, j'avais bien lu sur le site.....
Message Publié : 26 Juin 2013, 22:21
Download
Version 3.7, last updated 24th June 2013 [changelog]
SAMdisk37.zip — Windows 2000 or later.
Comment faut-il comprendre cela ?
Les versions OSX et Linux supportent les images disques avec le Kryoflux (pas encore les lecteurs réels) mais pas la version Windows.
OU
Seule la version Windows supporte les images disques et les disquettes réelles, alors que les versions OSX et Linux pas ?
Message Publié : 27 Juin 2013, 08:34
bon, je ne pense pas etre tres bon en anglais, mais pour moi c'est :
Les versions suivantes supportent les images de disquettes (.DSK) mais pas les lecteurs de disquettes physiques connectés a une machines (nappe sur controleur floppy d'un pc pour ceux qui sont long à la détente :mdr: ). Au moins, la création d'image reste possible en utilisant le kryoflux (en passant par son utilitaire qui fonctionne sur toute les plateformes) ou le discferret, et l'utilisation de SAMdisk pour la conversion avec la commande déjà donnée
Message Publié : 27 Juin 2013, 12:35
En fait j'ai déjà des jeux imagés avec le kryoflux, mais samdisk sous windows ne sait pas les traiter.
Samdisk windows ne sait pas et ne peut pas les convertir. La commande je l'ai essayée hier et Samdisk me rend la main, exactement de la même manière que si j'avais passé en ligne de commande une option qui n'a pas été prévue ou implémentée dans le programme.
Moi je suis fluent in english, et j'ai parfaitement compris que seules les version osx et linux peuvent convertir des images kryoflux au format DSK. Ce qui est là encore parfaitement logique puisque le créateur des routines, qui est un de mes potes, travaille à la base uniquement sous linux/unix et pas windows.
Il a conçu le logiciel Disk Analyse pour l'amiga principalement, mais ce dernier supporte aussi des logiciels dotés de protections "chiantes". Il a crée pour moi de base le support pour les disquettes protégées au format PC du sega system 24 et également les jeux amiga de feu la compagnie TLK Games (Tecnoball, Tecnoball Z et Equality version 1).
Juste mes 2cts.
Message Publié : 27 Juin 2013, 14:13
denis,
cela fait un petit mois que je fais des convertions des raw kryoflux vers dsk avec samdisk SOUS WINDOWS (avec des versions betas bien sur vu que la 3.7 vient de sortir ...)
je dois pas vivre sur la meme planete que toi et utiliser le meme samdisk du meme simon :mdr:
Message Publié : 27 Juin 2013, 19:07
denis,
j'ai essayé ta commande, et SAMDISK ne la reconnais pas. Point barre.
Message Publié : 27 Juin 2013, 19:17
ben la tu deviens franchement lourd :downnn:
reste sur tes convictions ...
les reset#10teurs pourront apprécier la commande qui fonctionne sans problème ce week end
j'aurais mon kryo, des d7 ... et des convertions raw vers dsk sous win 8 pro 8.1 (si j'ai le temps de faire la mise a jour :P )
Message Publié : 27 Juin 2013, 20:13
Lourd ? ta commande ne fonctionne pas ! Et faudrait en plus que je te dise que c'est bon ?
n'importe qui ici peut tester ta commande avec samdisk windows, ça ne marche pas !
PS : je vais poster ici un jeu imagé avec le kryoflux.
