en ce lundi, voici une bonne news pour tous les dumpers
Version 3.2 (2012-04-08) ------------------------ - Added general support for 1Mbps data rate, used by ED disks - Added 1Mbps support to IMD images, using new track modes 6+7 - Added --tty option to output console messages to non-console streams - Fixed crash reading gap data from oversized sectors (thanks Philippe!) - Fixed crash using --verify when writing non-simple images - Fixed gap data trimming when writing FDI+IMD images
Version 3.1 (2012-03-18) ------------------------ - Added --repair option to help combine damaged image dumps - Added write support for D88 images - Added support for IMD mixed sector sizes - Added record name from source basename, if no label available - Added more file sizes for raw image recognition - Added verbose track output for floppy->image dumping - Fixed IMD creation using 500Kbps instead of 250Kbps - Fixed bit alignment during IPF track wrapping - Fixed converting images to BDOS format when setting label - Increased --rescan matching distance from 32 to 64 bytes - Updated to zlib 1.2.5, using zlibwapi.dll instead of zlib1.dll
Version 3.3 (2012-06-14) ------------------------ - Added built-in support for zipped and gzipped files - Added support for repairing 8K sectors with bad CRCs - Added support for raw hard disk images - Added identify device data reading, where available (non-USB) - Added --hdf to force HDF version (10 or 11), with v1.1 now the default - Added --no-identify to ignore source identify data - Added --no-cfa to suppress CFA festures in generated identify data - Enhanced identify to include CHS/LBA28/LBA48 sector counts and CFA - Enhanced verbose disk list to show serial+firmware and MBR partitions - Changed disk list to show all devices by default, not just BDOS - Fixed repairing to blank target tracks, with new density check - Fixed HDD access beyond 4GB boundary, extended -s range to 2TB - Fixed SAD image writing with custom sector sizes - Fixed status messages being written to log and not erased correctly - Improved FDC integrity checks during sector reads, for suspect hardware - Improved total sector count to CHS mapping
Version 3.4 (2012-08-14) ------------------------ - Added create command for blank HDD and floppy images - Added basic IDEDOS partition listing - Added checking of good sectors to track repairing - Added support for Velesoft DSK/DS2 transfer images - Added --chrn to trust ID header over physical location - Added --no-1m to skip 1Mbps data rate scanning - Restored --byte-swap for Atom/AtomLite conversion - Improved ATA identify data handling - Improved scan output to report warnings above affected track - Fixed recognition of DSC/HDR, CFI, LIF disk images - Fixed floppy image conversion to .raw dump - Fixed repaired sectors retaining original track offset - Fixed detection of oversized tracks with just 1 sector - Fixed HDD firmware string missing final character - Fixed log file including empty status messages - Fixed AL+ boot sector being mistaken for MBR - Reverted to Visual Studio 2005 for old CPU compatibility
Existe t-il un tutoriel pour utiliser SAMDisk ? Je ne sais utiliser que CPCdisk XP pour mettre des jeux sur une disquette 3.5".
Hors, il y a certains jeux comme par exemple la compil "les justiciers" ou bien le jeux "zap't balls advanced edition" que je n'arrive pas à copier avec cpc disk xp (mon lecteur de disquette fait un bruit inhabituel sur certaines pistes durant la copie).
J'en avais parlé avec une personne lors d'une convention retro gaming qui m'avait conseillé SAMDisk. J'ai tenté de l'essayer mais je ne sais pas l'utiliser.
Et au cas il n'est pas possible de contourner ces protections, est ce que le HxC floppy disc permet de les contourner ?
Oui, sur la page de SAMdisk. Il s'utilise en ligne de commande, il faut donc ouvrir une fenêtre "DOS" pour ce faire et se positionner dans son répertoire. Le plus simple étant d'avoir les DSK au même endroit.
Pour créer une image disque depuis un original : SAMDISK A: FICHIER.DSK
Pour écrire une disquette depuis une image disque : SAMDISK FICHIER.DSK A:
Maintenant, tu peux essayer de déposer l'icône du fichier DSK sur l'icône du programme SAMdisk. Il est possible que ça fonctionne et que ça te demande d'insérer une disquette pour faire la copie.
@ TotO. Merci pour l'explication. Je viens de comprendre mon erreur
Ne connaissant pas très bien l'utilisation des commandes DOS, mon problème venait que je ne me positionnais pas sur le bon répertoire.
Pour les néophytes comme moi, je complète l'explication par un exemple :
installation de SAMDISK --------------------------- 1 - télécharger FDinstall et la dernière version de samdisk (trouvable ici : https://cpcrulez.fr/emulateurs_UTIL-DSK-samdisk.htm) 2 - exécuter fdinstall 3 - dézipper samdisk v3.4 et couper / coller par exemple dans le répertoire C:\Documents and Settings et le renommer samdisk
utilisation de SAMDISK ---------------------------- 1 - positionner un jeu au format dsk dans le répertoire samdisk (exemple : fruityfranck.dsk) 2 - démarrer / accessoires / invite de commandes 3 - dans la petite fenêtre, pour se positionner dans le répertoire, taper cd\documents and settings\samdisk
Pour installer le jeu sur une disquette : 4 - Taper samdisk fruityfranck.dsk a:
Pour transférer un jeu présent sur une disquette vers le pc 5 - Taper samdisk a: nomdujeu.dsk
J'ai tenté de copier la compile "les justiciers" sur une disquette mais ça n'a pas marché pour la face Robocop/Dragon ninja. Samdisk m'indique le message "aucune marque d'adresse ID n'a été trouvé pour la disquette". J'aimerais vraiment réussir à copier cette face pour refaire ma disquette 3" originale qui ne fonctionne plus.
Par contre, zapt ball advanced edition fonctionne
@Hermol, merci pour le lien. Après recherche, j'ai trouver SAMDisk GUI, il se trouve dans l'application JavaCPC Desktop téléchargeable ici : http://cpc-live.com/download.php?view.2 Après lancement de Javacpc desktop, samdisk GUI se trouve dans le menu Extras.
Par contre, je ne suis pas arrivé à l'utiliser mais ce n'est pas grave.
Version 3.5 (2013-01-07) ------------------------ - Fixed interleave and skew values for Pro-Dos .cpm images - Alignment tweaks to some output formatting - Restored code signing to help download validation
