Nous sommes actuellement le 13 Jan 2026, 23:51
CCZ80 compiler par Emilio Guerrero
 [ 25 message(s) ]  Aller vers la page Précédent  1, 2
 Sujet du message : Re: CCZ80 compiler par Emilio Guerrero
Message Publié : 04 Nov 2010, 08:35
Nov 2 2010 - New compiler version ccz80 3.0.1 for Microsoft .NET 4 with 25% more speed compiler.
Message Publié : 04 Nov 2010, 09:04
Nice ! ;)
Message Publié : 12 Nov 2010, 23:08
Nov 12 2010 New version ccz80 3.0.2:
* Use Microsoft .NET 4 Client Profile to reduce the requirements for the computer.
* Add some optimizations for generated code.
ccz80 IDE and sprUtilCPC sprites editor for Amstrad CPC is also compiled to Microsoft .NET 4 Client Profile.
Syntax files for editors adapted to ccz80 version 3.
Message Publié : 23 Nov 2010, 22:18
Nov 23 2010 - Included setup utility to download and install the compiler, documentation, tools, etc.
src/url : http://www.telefonica.net/web2/emiliogu ... ccz80.html
Message Publié : 05 Jan 2011, 22:40
Jan 5 2011 New IDE version 2.
Message Publié : 23 Jan 2011, 17:48
la 2eme update pour ce mois de Janvier
Jan 22 2011
Improved setup utility:
-Facilitate the implementation of ccz80 for different computers.
Create shortcuts for all installed documentation.
Compiler ccz80 version 3.1.0:
-Allows you to specify constant values of type byte, word and string as an expression of constant operands.
-Review and improvements to syntax check the source code.
Message Publié : 02 Fév 2011, 17:48
Feb 2 2011
Improvements in ccz80 IDE:
-New option Edit/Select block.
-Improvements in the outcome of the option Format / Formatting assembler.
-New button on Find/replace window to copy the marked matched lines to clipboard.
-Fix in the replacement of text within a selection.
-Initially mark all matches found in the Find/replace window.
Compiler ccz80 version 3.1.1:
-Fix for running applications indicated by the /post option when the path contains spaces.
-Improved formatting of generated assembly code with /asm option.
url : http://www.telefonica.net/web2/emiliogu ... ccz80.html ;linked:
Message Publié : 03 Fév 2011, 23:27
Feb 3 2011
- New library function for Amstrad PCW. Also applies with some exceptions for Amstrad CPC in 6128 and Spectrum +3 CP/M Plus.
- Added in setup utility the option to install the environment for Amstrad PCW using this new library.
Message Publié : 05 Mars 2012, 11:28
Compiler ccz80 version 3.1.3 (Mar 4 2012):
-Fixed the value returned by relational operators.
-Allow positive and negative values at the displacement of the assembly instructions with indexed records.
-Division by zero detection in expressions in ccz80 code and in expressions in assembler code.
-Fixed character encoding of text files generated.
-Allow constant string as second parameter in substract.
-Alloc numeric constant as condicion of condicional operator.
-Added label __begin_program at start of program.
-Added new functions in standard.ccz80 library: absb, absw, sgnb, sgnw, min, max, sqrt, power, previousrand, signedword, endprogram.
-Fixed functions btoh and wtoh in standard.ccz80 library.
-Fixed functions cursor, key, finputc, finputs and eof in Amstrad CPC libraries.
-Optimization of function copychr and improvement in function save in Amstrad CPC libraries.
url/src: http://www.telefonica.net/web2/emiliogu ... ccz80.html
Message Publié : 18 Mars 2012, 05:26
Mar 17 2012 : ccz80 IDE version 2.0.0.5: fixed problem that blocked the IDE when the result of the compilation produced too much text.
