SAMdisk is a command-line disk image utility for Windows 2000 or later.
The utility supports transfers between floppy disks and disk images, and is designed to work with almost any soft-sectored disk format compatible with the PC floppy controller, including some copy-protected formats.
Low-level floppy device access requires the fdrawcmd.sys driver to be installed.
changelog:
Version 3.0 (2010-06-20) ------------------------ - Largely re-written again, for non-uniform track support - Added +3 protections: Speedlock weak sectors, OperaSoft 32, various motor bug fixes - Added CPC protections: Speedlock/EA weak sectors, Infogrames/Loriciel gaps, KBI-10, KBI-19 - Added support for many disk image containers, including EDSK, TD0, DMK, IPF - Added support for zip, gzip and bzip2 archives using zlib1.dll and bzip2.dll - Added directory support for MGT, TR-DOS, Opus, Didaktik and Amstrad CP/M - HDD support for drives up to 2TB, with improved lock/dismount and safety checks - Changed to Unix-style getopt for command-line options - Removed embedded fdrawcmd.sys driver
