Nous sommes actuellement le 10 Juin 2026, 02:41
Reloaded amstrad Emulator for Windows
 [ 8 message(s) ]
 Sujet du message : Reloaded amstrad Emulator for Windows
Message Publié : 08 Juin 2010, 21:11
Message(s) : 5136
The Caprice Reloaded emulator, with integrated assembler and debugger.
Installation under Windows for v0.304
As of now, there is no automated setup, so here are some hints :
Most of the data is stored in Document and settings/your_user/application data/reloaded/
In this folder you need Keymap.cfg, and a folder called roms with the roms you want to use (usually cpc6128.rom and amsdos.rom, but you can add more). That should set you up, you can place all the other files anywhere on your harddisk.
url : http://code.google.com/p/cpcsdk/ ;linked:
 Sujet du message : Re: Reloaded amstrad Emulator for Windows
Message Publié : 10 Juin 2010, 12:54
Message(s) : 5136
la version r309 est dispo depuis quelques heures
url : http://code.google.com/p/cpcsdk/downloads/list ;linked:
Message Publié : 12 Juin 2010, 22:19
Message(s) : 5136
r320 est dispo...
* IPC system to load a dsk or snapshot into an already running instance of Caprice from an external command line.
* Backport z80 fixes from Mame 3.9. Should fix OUTI/INI§/IND/OUTD/INIR/OTIR/OTDR/INDR, and BIT undocumented flags behaviour. Stil failing on ADD IX,reg16 test, I can't spot the problem...
* [bugfix] Correct an error in the ROM gestion:
- segfault when no ROMs in user dir
- instead of reading ROMs in system dir, readin in user dir (and then segfualt when n ROms in user dir)
* [bugfix] Uncomment nextSample which is required in order to compile
* Fix the disassembler as windows doesn't like having tabs in a listbox * Also work around a bug in windows that prevent getting monospaced fonts
* Support for the MEMPTR regiter. Hopefully I got it right.
* Render frames to screen only every 50Hz. This still allow climax intro to render but make the screen flipping pictures a lot worse
* Remove the now unused exit condition from z80 : psg buffer full
* Fix the down key in the keyboard setup
* Fix the radio buttons for 50/60Hz and ram size being in the same group
* Fix the radio buttons for 50/60Hz and ram size being in the same group.
Message Publié : 16 Juin 2010, 21:18
Message(s) : 5136
nouvelle version : r330 dispo sur le site ...
Message Publié : 06 Sep 2010, 21:21
Message(s) : 5136
la nouvelle version r401 dispo : :eng:
Message Publié : 31 Jan 2011, 09:31
Message(s) : 5136
New version of Reloaded for Windows.
* Video rendering should be a little faster
* Display a crosshair where the electron beam is in pause mode (a bit inaccurate)
* Fix some problems with VBL and jumper settings
* Disk editor also works for drive B, so you can copypaste sectors around between two DSKs
* Some other small fixes
url : http://code.google.com/p/cpcsdk/downloa ... ed_r449.7z
Message Publié : 03 Juil 2011, 20:53
Message(s) : 5136
version r488
In this release :
* The experimental IDE is included again
* Fixes in the sound system
* Various other smaller bugs fixed
http://code.google.com/p/cpcsdk/downloa ... ed_r488.7z
Message Publié : 27 Sep 2011, 18:55
Message(s) : 5136
version r533 est sortie... pas mal de news depuis le dernier build, aller donc faire un tour sur le site google.code pour tout savoir ....
 [ 8 message(s) ]
