Nous sommes actuellement le 09 Sep 2026, 08:11
[EMU] DSP
 [ 9 message(s) ]
 Sujet du message : [EMU] DSP
Message Publié : 29 Mai 2010, 20:38
En ligne
05/27/2010: New version DSP 0.10!!
- General
+BUG: Fixed the huge virtual memory reservation! It was the TAPE module, now uses pointers and uses memory as it's needed.
+BUG: TMS32010 - Fixed some bugs in flags, added many opcodes (now you can finish wardner)
+NEW: Improved keyboard and joystick system. Now the keys can be redefined and you can select a joystick for each player (general configuration menu) and added second player controls, and two players can play together (BubbleBobble, ExedExes, etc).
+ENHANCE: Reviewed all drivers to add all entries (coin, start, second player, etc).
+ENHANCE: M6502 - Some corrections (did not apply the timmings of the IRQ and NMI to the timers), and improvements in timings.
+BUG: YM2203 - Fixed internal timers, removed many drivers CPU sound clock hacks
+BUG: YM3812 - Fixed internal timers, removed many drivers CPU sound clock hacks
+ENHANCE: Added initialization of video plane and GFX. Fixed some bug on 'Psychic 5', 'Toki', etc
+NEW: Added preliminary NEC v20/v30/v33 CPU
-Pacman Hardware
-Pac-man
+ENHANCE: Updated driver, better memory map
-Ms. Pac-man
+NEW: Added driver with sound
- Lady Bug
+BUG: Fixed VBlank, works again
- Bubble Bobble
+ENHANCE: AT LAST! Sound works!
- City Connection
+BUG: Fixed background
- Tehkan World Cup
+ENHANCE: Added controls, playable. Some sound issues and minimal graphics bugs.
- Galaxian Hardware
-JumpBug
+BUG: Fixed last memory map bugs. Now works.
- Rally X Hardware
-New Rally X
+BUG: Fixed a bug that prevent the driver to boot
- Shoot Out
+BUG: Fixed coin insertions
- Express Raider
+ENHANCE: Only one coin per insertion
- Wardner
+ENHANCE: Fixed sprites
- Legendary Wings Hardware
-Trojan
+NEW: Added preliminary ADPCM sound
- Gaelco HW
+NEW: Added basic driver without sound
-Big Karnak
+NEW: Added driver, misses correct video implementation
- Exed Exes
- 1942
- Gun.Smoke Hardware
Gun.Smoke:
-1943: Battle of Midway
-1943 Kai: Midway kaisen
- Jail Break
+NEW: Added driver with sound, some sprites bugs
- Circus Charlie
- Iron Horse
• -Irem M72 Hardware
-R-Type
+NEW: Added a basic driver, without control or sound
url/src: ;linked:
http://leniad.cjb.net/
http://leniad.cjb.net/dsp/downloads.htm
http://code.google.com/p/dsp-emulator
 Sujet du message : Re: DSP 0.10
Message Publié : 15 Sep 2010, 17:54
En ligne
New version DSP 0.10b2!!
• General
+ENHANCE: Z80 - Run one last instruction after EI
+ENHANCE: M6809 - Cleaning the code, more clarity and speed.
+ENHANCE: M68000
You can download the new binary (for windows) and the source from here. Remember you can also download at Google Code
url : http://leniad.cjb.net/dsp/main.htm
Message Publié : 22 Sep 2010, 19:38
21/09 - DSP Emulator 0.10b3 WIP 20/09
Fixed Spectrum driver initialization, added some opcodes to M68000
CPS1: Added priorities between sprites and planes, fixed sprites, fixed transparent tiles and added Strider, Three Wonders, Captain Commando, Knights of the Round and SF2' Champion Edition.
Some more screen shots...
http://leniad.cjb.net/dsp/index.htm
 Sujet du message : Re: [EMU] DSP
Message Publié : 20 Oct 2015, 12:22
Message(s) : 3693
26/09/15 - DSP Emulator 0.16 WIP Uploaded
Amstrad CPC 464,664 & 6128
- ROMS - By default the files are:
-CPC-464: 'CPC464.ZIP' --> 'cpc464.rom' CRC: 0x40852F25
-CPC-664: 'CPC664.ZIP' --> 'cpc664.rom' CRC: 0x9AB5A036 and 'amsdos.rom' CRC: 0x1FE22ECD
-CPC-6128: 'CPC6128.ZIP' --> 'cpc6128.rom' CRC: 0x9E827FE1 and 'amsdos.rom' CRC: 0x1FE22ECD
- Keyboard: Mapped the keys for each of the CPC. To press the '|' press left shift key and '><' next to the Z.
Emulation of pressing keys 'F1' to 'F10' you must press right Shift at the same time.
- Joystick: Emulated with the redefinable keys or external joystick.
- Virtual Tape: you can load ZIP, CDT, WAV and CSW. Are working the classical loading squemes (bleepload, alkatraz, SpeedLock ...). Use the mouse to move inside the virtual tape and select the starting position.
- Sound: All version have the AY-8912 chip
- Floppy disk: Emulated the functions of the NEC-765, just missing writing functions. Supports the format 'DSK' and the 'extended' DSK formats.
- Snapshots: Support load/save 'SNA' format
- To do
- Some disk protections are not working (a few left)
- Some video effect are missing (M6845 chip)
greatxerox
Message Publié : 12 Avr 2016, 23:32
Message(s) : 10
bonjour
nouvelle version de DSP complètement fonctionnelle.
http://amstrad.eu/modules/news/article.php?storyid=1992
personnellement, je l'utilise pdt le stream du jeudi, il va très bien (l'auteur m'envoie régulièrement des versions que je béta-teste)
 Sujet du message : Re: [EMU] DSP v0.16b2 FINAL
Message Publié : 13 Avr 2016, 08:57
Message(s) : 3693
Merci pour l'info greatxerox , voici le changelog :
10/04/16 - DSP Emulator 0.16b2 FINAL released. Source, Win32/64 and Linux 32/64 available.
So much updates and enhancements, and at last a ROM/Samples information export. Please read the documentation or the wiki (Spectrum and Amstrad CPC have keyboard changes).
Many thanks to greatxerox and Davide.
29/03/16 - DSP Emulator 0.16b2 WIP source and Win32 updated.
-Added to download SDL library 2.0.4 for Windows 32/64 bits. You can also download from http://www.libsdl.org
-DSK file engine
+Added patches to fix the some Titus protections in Amstrad CPC
-Tape file engine
+General cleaning
+CSW format: File opening rewrited, improves stability.
+TAP format: Standardized opening files through data structures
+TZX format: Standardized opening files through data structures
+PZX format
-Standardized opening files through data structures
-Corrected data block
-Properly implemented very large pulses
-Spectrum
+ Mapped some missing special keys
src: https://github.com/leniad/dsp-emulator
 Sujet du message : Re: [EMU] DSP v0.16b3 WIP
Message Publié : 09 Mai 2016, 16:50
Message(s) : 3693
08/05/16 - DSP Emulator 0.16b3 WIP. Source and Windows 32 WIP binary.
-General
+Fixed snapshots loading in some drivers
+Fixed value and type of the amplifier in some sound chips
+Cleaning some CPUs
+Completely eliminated references to the 'SDL2.pas' unit and improved the 'lib_sdl2.pas' to be independent
+GFX: fixed left rotate of the nonsquare graphics
+Z80
-Removed the special case of HALT opcode
-Fixed possible loose of timings after the execution of an opcode
+YM3812: Converted to classes
+Konami Sound
-Converted to classes
-Integrated Z80 sound CPU
-Integrated Frogger and Scramble sound driver
-Improved and corrected some drivers
-Separated into four types 'Time Pilot', 'Jungler', 'Frogger' and 'scamble'
+Updated 'Galaxians' samples and added 'Space Invaders' samples
-Sega System 1
+Added custom Z80 timings
-Popeye
+Added 2nd player controls
+Driver cleaning
-Galaxian HW
+Galaxian: Added several sounds (samples)
+Fixed stars background
-Space Invaders
+Added driver with sound (samples)
-Centipede
 Sujet du message : Re: [EMU] DSP 0.18
Message Publié : 06 Déc 2017, 22:16
Message(s) : 3693
. Win32 binary and source updated. a écrit :
DSP Emulator 0.18WIP:
Enhanced Amstrad CPC emulation
+Better CPC Z80 timings
+Added configuration for tape motor, you can select if it is used in the emulation of the virtual tape or not
+Improved video (registers, vsync, hsync, etc.)
+Improved memory management, 512Kb expansion it's working properly
+Improved interruptions
DSP Emulator 0.17 Final.:
+Added support for the snapshot V3 chuncks (including compressed memory)
+Added LensLok protection
+Added support for IPF files natively without external libraries.
+Enhanced video mode 2, more speed
+Fixed WAV tape file loading
Message Publié : 21 Avr 2022, 17:15
Message(s) : 3693
DSP Emulator updates "Amstrad CPC":
v0.20WIP4 : +Lens Lock -Fixed Amstrad decode mode
v0.18b4 WIP : +Resize screen size, it was too big, now it's 384x272 pixels (Thanks to Neville)
v0.18b3 WIP : +Fixed screen flickering (Thanks to Neville)
 [ 9 message(s) ]
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 73 invité(s)
