Nous sommes actuellement le 10 Juin 2026, 01:57
Arkos Tracker revealed
 [ 56 message(s) ]  Aller vers la page 1, 2, 3, 4  Suivant
 Sujet du message : Arkos Tracker revealed
Message Publié : 20 Fév 2010, 18:03
Message(s) : 5136
19/02/2010 :: Arkos Tracker revealed...
In a few weeks shall be released Arkos Tracker, a Windows-based tracker to compose on PC songs for CPC, but also for any computer that has the same sound processor.
For now, only a tiny video can be found here.
But soon, a whole pack with the Z80 players, tons of songs and sounds will be released...
url : http://arkos.cpcscene.com/ ;linked:
norecess
 Sujet du message : Re: Arkos Tracker revealed
Message Publié : 21 Fév 2010, 04:08
Vraiment cool, plein de potentiel. Je retiends surtout l'ouverture à toute la scène AY, finalement :) cool !
Message Publié : 21 Fév 2010, 05:14
Message(s) : 5136
oui, un sympathique alternative made in France au Vortex Tracker II de S.V.Bulba
Message Publié : 21 Fév 2010, 08:39
Et en plus on y gagne la gestion des bruitages !
Message Publié : 21 Fév 2010, 20:07
Message(s) : 5136
Targhan viens de balancer la new sur cpcwiki ,
Hi,
Arkos will soon release a Windows-based tool to create your music for CPC. It's a bit like the STarKos, only more powerful and intuitive. Sound is outputed to your sound card, or directly to your CPC in real-time if you have a CPCBooster !
Here's a little preview :
http://www.youtube.com/watch?v=x3xqWeJjxVA
Some features of Arkos Tracker :
- 256 patterns available.
- Each pattern is composed of 3 independent tracks.
- 512 tracks available, each being reusable in any pattern, or even several times in the same pattern.
- Each track can be transposed independently in a pattern.
- A track has a height from 1 to 128 lines, independently of the pattern that uses it.
- 255 instruments available.
- The instrument editor allows you to modify each registers of the PSG.
- Replay frequency of 13, 25, 50, 100, 150 or 300hz.
- Possibility to put "events" in your song. They can either be used to synchronize your music with your production, or trigger digidrums for exemple.
- Big news : instruments are divised into two channels : a Software, and Hardware one. These channels can be independant or dependent from each other. Allows using two waves at the same time !
- Allows you to play sound effects in a very flexible and powerful way. You can also play the SFXs without any music.
- You can import any STarKos song.
- NO SID/DMA for CPC+ for now. I may plan that...
About the Player :
- Only 25 scanlines maximum used !
- On top of being faster than the STarKos player, it's lighter : one and a half kb.
- The player works on Amstrad CPC, MSX, Spectrum or Pentagon (using conditional assembling : only the necessary code is used).
- The generated songs are very light (about as much as the STarKos song. Sometimes a bit lighter, sometimes not).
- Can be used in Basic (call the player by yourself, or use it under interruptions), and Assembler.
- The source of the player is given, and documented.
- The format of the music is given. So you'll be able to create your own custom tools (conversion, new players...).
- Fade in/out available.
About the sound effects :
- Every instrument of your song becomes a sound effect.
- You can play/stop a sound effect on any, or all, of the 3 channels.
- You can choose the note, volume, speed of any triggered SFX.
- You can add Pitch to them (useful to add randomness to the sounds, for example).
- Sound effects are in a seperate file : you can use the same sound bank even if you change the music.
For the hardcore composers among you, nothing will prevent you from using STarKos. You can import you SKS song, convert them with Arkos Tracker, and use the new players !
I hope to release the tool in 2 or 3 weeks.
Thanks for reading and see you soon,
Targhan/Arkos.
url : http://cpcwiki.eu/forum/index.php/topic ... 4.html#new
jegougou
Message Publié : 10 Mars 2010, 11:26
Message(s) : 79
enorme, faut que je test :winner:
Amigavibes demoscene podcast & Web Radio
Message Publié : 14 Avr 2010, 04:28
Message(s) : 5136
ca y est , ce tracker est disponible au téléchargement :
Arkos Tracker 1.0 Beta
Code : Targhan
Additional Design : SuperSylvestre/Les Sucres En Morceaux.
Output and AY Emulation libraries : Augusto Ruiz Garcia.
Release date : April 2010.
Platform : Windows-based PC with .NET framework.
url/src:
http://www.arkos.cpcscene.com/
http://www.julien-nevo.com/arkos/tools.html
Message Publié : 18 Mai 2010, 18:38
Message(s) : 5136
des news ....
18/05/2010 :: Arkos Tracker V1.0 Beta 2
A new beta for our Windows-based Tracker.
Here's the changelist :
-Complete coding of the sound generating and outputing by myself. The emulation is more accurate, and will allow the implementation of samples and Sids in the future.
-Plug in your best MIDI Keyboard or any MIDI-In device, play and record your music with it !
-150hz and 300hz replay modes are now available. They are very slightly slower than on a real CPC. Nothing you should notice...
-CPCBooster output is now very accurate.
-Ability to save Interleaved/non-Interleaved YM6 format.
-AKStoBin : a command line software to converts any AKS song into a binary to use on hardware (warning, you still need .Net to use it).
-STKtoAKS : a command line software to converts any STarKos songs into an AKS song (warning, you still need .Net to use it).
src/url : ;linked:
http://arkostracker.cpcscene.com/
Message Publié : 13 Juin 2010, 12:52
Message(s) : 5136
11/06/2010 :: Arkos Tracker V1.0 Beta 3
A small beta for our Windows-based Tracker.
- AKStoYM, a command line tool to convert any AKS song into an interleaved or non-interleaved YM6 format.
- MSX2 compatible player test thanks to WYZ.
* If you don't have .Net, you can still use the command line tools (AKStoYM, STKtoAKS, AKStoYM) if you have Mono installed.
src/url :
genesis8
Message Publié : 13 Juin 2010, 23:10
Message(s) : 83
J'en ai profité pour proposer la news sur MSX.ORG.
http://www.genesis8bit.fr/indexf.php
News Amstrad CPC bilingue anglais-français
Message Publié : 29 Juin 2010, 20:49
Message(s) : 5136
Arkos Tracker V1.0 Beta 4
Ability to drag'n'drop AKS, AKI, SKS files into the Arkos Tracker.
Ability to limit the Pattern Viewer refresh rate in order to improve performance.
Load Song and Import SKS options are now mixed into one single option.
Corrected a bug that could make the Pattern Viewer not refreshed after having entered a volume, pitch or instrument.
Corrected a bug that would make the player use a wrong frequency when changing the replay frequency.
Corrected a bug that would make sounds not evolve on Speed 1 while adding them in the Pattern Viewer.
Slight improvement of the replay routine (shouldn't be noticeable in 16 bits, but should in 8), after Dadman noticed a bug in the 8 bits replay.
A few cycles optimisations of the player (thanks to Grim/Arkos).
Spectrum player redesigned, corrected, and optimised by Grim/Arkos (using the "Molusk" song, max TM is 5300t, average is 2400t).
MSX player test debugged by Syx. MSX DSK updated by Syx.
Source of the CPCBooster client and management now included (Sources/CPCBooster).
url : http://www.julien-nevo.com/arkos/index.htm ;linked:
Message Publié : 09 Juil 2010, 21:31
Message(s) : 5136
The betas seemed stable enough, so let's make a V1.0 out of them !
The "Load Song" dialog can now load both AKS and SKS files at the same time.
You use use the command line to load a song.
Drag'n'drop possible to the Arkos Tracker executable file to load a song.
Bug corrected : Could not close the application with the top-right cross when the player was active.
Go into the Tools section to download it !
Message Publié : 13 Jan 2011, 16:55
Bon là je suis justement en train d'essayer de me mettre a cet Arkos tracker.
C'est pas mal, je progresse dans la compréhension mais y'a pas mal de trucs qui me chagrinent un peu.
=Tempos et durées des notes :
bin euh... moi à la base je faisait de la guitare.
Et là la notion de longueur d'une note (noire, ronde, double croche voire triolet...) bin je ne la retrouve pas alors que c'est assez fondamentale pour de la zique.
Ok, pour avoir des notes de longueur différentes, il faut je pense avoir un "instrument" pour chaque longueur de note que l'on souhaite.
ça se comprend car on est dans une optique au plus prés du composant électronique que l'on programme alors comme en vrai.
Mais quand même dans un utilitaire qui tourne sur un système moderne, c'est un peu pénible je trouve.
Enfin pas pénible, mais euh... ça semble assez exotique tout de même.
OK les morceaux Trackers sont souvent de type techno avec des sons mécaniques et tout et tout...
=De même que pour les Tempos.
on peut en effet définir des écarts (steps) entre les notes quand on les entre dans les Tracks. Mais une colonne en plus pour avoir des mesures faciles ça aiderai un peu à moins s'y perdre quand on souhaite transcrire une partition par exemple.
Et le Herzage (replay) et Speed, c'est pas euh... pas facile de savoir à quel Tempo musical ça correspondrai.
Bref intégrer quelques mécanismes que l'on trouverai plus dans les utilitaires MIDI ou genre guitarpro (utilitaire de partitions et tablatures...) par exemple, ça ne ferait pas de mal pour les néophites.
là j'ai mis la main sur TuxGuitar qui est un guitarpro freeware...
Et alors pouvoir peut être importer des partitions de type guitarpro ou je ne sais quel Midi...
ça ferait qu'n passerai sans doute moins de temps sur la transposition des notes et plus de temps sur le travail du son en lui me^me... ou donnerai des bases de travail assez rapidement...non ?
=Pattern éditor :
Bon, ça passe encore, hélas je ne vois pas coment on peut faire pour checker proprement les différentes Tracks implémentées...
y'a pas un moniteur des Tracks ?
Genre euh... souvent le "display" pour le mixage des différentes parties est horizontal sur les utilitaires de sons modernes.
Nuendo par exemple...
Là donc (Arkos Tracker) d'après ce que j'ai compris, on a bien sur des patterns qui sont un "mixage" des 3 canaux... ou l'on y met donc des Tracks, soit euh... des séquences musicales mono-voix donc...
Mais comment fait on quand on veux mixer proprement à partir d'une "base de donnée" de tracks...?
il faut écrire sur un bout de papier les différentes tracks pré-implémentée ? ne pas se perdre ?
Peut on importer juste des Tracks ?
=De plus pour un bon mixage, on peut avoir/vouloir des séquences (tracks) plus ou moins longue, bin là ça reste cantoné à la longueur de la pattern...mmm...
pas forcément grave, y'a sans doute moyen de s'arranger avec une pattern super longue (à voir) et alors découper le reste comme il faut...
ça fait tout de même du "calcul" à se taper.
=De même quand on veut faire des copier/coller de petites séquences, une "rêgle" ça serait pratique... ça indiquerai de manière graphique les mesures ou ce genre de chose.
Il y a bien sûr la première colonne qui numérote et met en blanc les notes toutes les 8...donc oui ça fait du 4/4...genre...
Mais une autre colonne dans le même genre, avec des symboles de "notes" type "ronde, blanche, noire, croche, double-croche" ou que sais-je, ça serait bien.
=importer/sauvegarder des instruments :
bin là, quand on importe/charge un instrument, déjà on doit les importer/charger un par un...?
C'est pas possible d'importer directe un set complet d'instruments ?
Ensuite il me semble qu'il faut les renommer individuellement à chaque fois...
Il prennent pas "automatiquement" le nom de l'instrument (du fichier AKI donc) par exemple ???
Faut pas 'y perdre...
=quesqu'on est en train de jouer sur son clavier de PC ???
En gros un petit bout de fenètre qui t'indique quelle note tu sort avec le clavier (en direct donc) cça serait bien, parceque que moi je m'y perd vite car sur un Azerty de PC c'est pas pareille que sur un piano de midi...
Et j'ai pas un clavier spécial dédié à cette application avec les notes écrites sur les touches et de la couleur et tout et tout.
Et je pense ne pas être le seul dans ce cas...
Bien sur on peut utiliser une Track de libre en mode enregistrement pour ça mais bon...
=euh, dans une track que l'on édite (enregistre donc)...
Quand on efface une note (sélectionné puis supprimé...) bin ça décale toutes les autres notes d'après...
Pourquoi elles ne restent pas forcément à leur place dans la séquence ?
Est ce que c'est un truc que je ne sais pas encore faire ou ça n'est pas implémenté de la sorte ?
Bon voilà, donc je continu mon exploration de l'Arkos Traker, après mes questions ne sont pas des reproches, juste un point de vue de néophyte...
en tout cas c'est pas facile d'accès les trackers.
La Logique est assez différente de la musique "traditionnelle" dans les codes et langages utilisés... et dans les mécanismes.
En tout cas ce sont des suggestions qui n'engage à rien, et je verrais aussi si j'arrive a m'y faire malgré tout... :sweatingbullets:
Targhan
Message Publié : 13 Jan 2011, 19:16
Message(s) : 16
Hop,
Laisse moi te donner quelques réponses...
Autre possibilité, tu utilises une note qui a un sustain infinie, et tu créé un 2e son qui va faire le fade out, quand tu en auras besoin. Ou tu fais le fade out toi même avec du volume dans la colonne appropriée.
Non, tous les trackers fonctionnent comme ca...
Pas vrai non plus :). Je te suggère de regarder comment les morceaux d'exemple sont conçus, d'ailleurs.
La, rien a faire concernant la transcription en BPM. Mais a l'oreille, tu devrais t'en sortir. De toute facon y'a pas 40000 possibilités :).
En ce qui concerne les "mesures faciles", tu peux changer le "highlight" des lignes dans les options de la musique (toutes les 3 lignes si tu fais du ternaire, etc)...
Clairement, ce n'est pas comme ca qu'il faut s'y prendre. Les trackers ont un systeme a part auquel il faut s'adapter. Encore une fois, a l'oreille, normalement c'est faisable pour un musicien.
>=Pattern éditor :
Euh ? Hein ? Tu as le Linker en bas à gauche, verticalement.
Hein ? :) Tu peux associer des tracks à des noms (qui apparaissent en surimpression) ou des couleurs si tu as peur de te perdre.
Non...
Normalement ce n'est pas utile. Les patterns "super longues" sont à éviter (pas pratique), de toute facon tu es limité à une hauteur de 127... A toi de bien découper ta musique en séquence logique (4 mesures par pattern par exemple).
Non, ce serait vraiment, vraiment une mauvaise idée. Les trackers ne sont pas fait pour ca. On doit justement pouvoir s'affranchir de ces notations quand on compose avec un tracker.
Non. Je pars du principe que, soit tu vas recréer la plupart des instrs, soit tu vas piocher dans la liste pour tester ceux qui t'intéressent.
Hein ? non. Si c'est le cas, c'est un bug, dis moi comment tu le créés.
Si tu en as besoin, va dans l'editeur instrument, la note jouée apparait en haut au milieu.
Question d'habitude, moi c'est sur un clavier midi que je suis perdu.
Utilise Delete, pas Suppr.
Good luck,
Trg.Aks
Message Publié : 13 Jan 2011, 19:28
Sûrement comme un manche, lol...
Bon alors :
Voui j'ai un peu fait des progrès encore, à force de tâtonnements.
Bon en gros pour ce qui est de transposer/importer les notes depuis un utilitaire genre guitare pro, j'ai trouvé la solution...
sur Tuxguitar y'a un truc qui d'appel "éditeur de la matrice"...
Et ça indique super bien els longueurs des notes et surtout les dites notes à la même numérotation que Arkos Tracker...
Donc ok, ça peut se faire à la main en multi-fenêtre...
Après euh...bin si je ne met pas la bonne note du bon coup, l'habitude vient et on peut toujours re-écrir une nouvelle note dessus moyennant un click en plus...
Pour l'éditeur des patterns ça vas, je fait des progrès aussi je pense.
le petit problème donc c'est si on cherche a faire des triolé je pense... bref tu ternaire...
Quoique la musique celtique voire certain Rocks/métals en utilisent aussi pas mal...
Mais avec du tâtonnement doit y avoir moyen de se démerder donc... ok
par contre Height ??? c'est en quoi ?
les notes sont en Hexdécimal dans l'éditeur de tracks, mais le height dans l'éditeur de pattern c'est quoi ? aussi de l'Hexa ?
20=1F notes...? arf merde, la numérotation commence 00 donc vi c'est bien de l'hexa-décimal lol...chui un peu distrait parfois...
Bin ça par exemple utiliser le 0 comme point de départ je ne sais pas trop si c'est bien musique traditionnelle lol...
Mais ok ça va j'ai compris aussi finalement.
>=Pattern éditor :
C'est quoi ce fumeux "Linker" justement ? le "pattern éditor" ? enfin euh je veux dire ok le cadre en bas à gauche...
Donc le pattern éditor c'est aussi le Tracks editor en fait...
ok, de ce côté là ça va mieux aussi, j'ai un peu mieux compris...
Mais le truc c'est que dans ton morceau, comment tu peux savoir quelles tracks tu as de faites ? je sais que chaque morceau possède un nombre (256 ?) de tracks... c'est bien ça ? (ou un truc dans le genre)
Mais justement il manque un track browser... un truc dans le genre quoi...
Bref ça serait bien un fonctionnement avec peut être un onglet en plus...
un Track manager ou tu peux voir les slots de tracks qui ont eut une modif/du contenu...
Et ceux qui sont alors vides/vierges...non ?
Mais bon, ça devrait quand même rentrer dans ma petite tête....
Ah euh, un undo c'est pratique aussi...
Bon là je tente de transcrire Derezzed de DaftPunk...
D'abord faire les notes comme il faut, puis je verrai pour les instruments...
là j'ai pris des instruments de Thargan : Oops... comme base de départ.
Pour l'histoire des longueurs de notes, vi, je vais voire un peu mieux pour les instruments en eux même donc.
Mais c'est quand même bien déroutant au départ les soundtrackers.
Merci Tharghan pour ta patience et tes réponses...
