DSP Emulator 0.9ß4 released. Binary (Windows) and source code.
News 03/07/2010: New version DSP 0.9ß4!! • General +ENHANCE: New function to scroll a screen, but moved within another screen. +ENHANCE: M6809 + Added opcodes $10EE, $10EF y $102C + Cleaned code of opcodes $10XX. +ENHANCE: Added functions for not standard sizes sprites and transparent chars based on color table +ENHANCE: NAMCO Sound + Simplified, now only uses one audio channel and voice are mixed internally + Added 8 voices sound +BUG: At last! Fixed sprites cuts (Ghost'n'Goblins, Black Tiger, Pacman, etc). A lot of corrections in the sprites functions and data structures +BUG: In windows, if they were not language files DSP exit without any error +BUG: In linux the first run does not load the driver, temporarily patched (Lazarus Bug?) +BUG: If you open a tape on Amstrad or Spectrum and change to arcade, change the screen size correctly +BUG: If you open a tape on Amstrad or Spectrum, DSP can not find any ROMs file +ENHANCE: M68000 + Started a rewrite of the core, more speed + Enhanced the use of stacks (user and supervisor) + Added exception 1111 +NEW: M6800 - Added CPU series. Missing some opcodes and without SCI. +ENHANCE: Integrated 'Frogger' driver into 'Galaxian' hardware +ENHANCE: Integrated 'Kung-Fu Master' driver into 'Irem M62'hardware +BUG: Fixed small & silly bug in thelenguaje directory variable in Windows +BUG: Now shows the selected lenguaje +NEW: TMS-32010 - Added CPU, 95% completed • Spectrum +ENHANCE: Now remembers the last tape or disc selected and previewed in the tape or disk loader +BUG: Spectrum+3 - It does not change the page of video memory when paging is disabled, fixes the Atic-Atac (and others) +BUG: Spectrum 128k - Fixes ROM load • Rygar +ENHANCE: Sprites uses the new sprites functions, not duplicating the graphics • Rally X Hardware - New Rally X: Added driver • Psychic 5 +ENHANCE: Fixed initial screen effect • Irem M62 Hardware +NEW: Added sound and ADPCM +NEW: Implemented sprites priority -Kung-FU Master: Added sound -Spelunker: Added driver with sound -Spelunker II: Added driver with sound -Lode Runner: Added driver with sound -Lode Runner II: Added driver with sound • Mappy Hardware +NEW: Added 8-voice polyphonic sound +ENHANCE: Fixed scroll +ENHANCE: Added graphical priorities +ENHANCE: Fixed sprites. -Mappy +ENHANCE: Fixed the last graphical bugs -Dig Dug 2 +NEW: Added driver -Super Pacman +NEW: Added driver • Toki +ENHANCE: Fixed background +ENHANCE: Fixed sprites • Snow Bros +ENHANCE: Added sound and controls • Galaga Hardware -Galaga +NEW: Added driver, don't work because the custom IO are not working • Xain'd Sleena +NEW: Added driver with sound. • Suna +NEW: Added driver with sound and DAC. Video only have sprites! -Hard Head: +NEW: Added driver. -Hard Head 2: +NEW: Starting the driver, do not work nothing at all! • NMK 16 +NEW: Added base driver without sound -Saboten Bombers: Added driver -BobJack Twin: Added driver • Knuckle Joe +NEW: Added driver with sound • Wardner +NEW: Added driver with sound, small sprite problems You can download the new binary (for windows) and the source from here. Remember you can also download at Google Code
