Nous sommes actuellement le 15 Jan 2026, 06:09
[EMU] CPCEPower v2011
 Sujet du message : [EMU] CPCEPower v2011
Message Publié : 15 Nov 2020, 19:41
Nouvelle version v2011 qui inclus ces changements :magic: :
2020/11
PPI: for ASIC, the port A is always readable and writable even if the bit in the Control Register is activated or not. Thanks to AsT and Offset to have pointed it out !
CDT: Corrected a potential bug on ARM using a char instead of an unsigned char for pushBit
FULLSCREEN : now the emulation is paused when fullscreen lost focus with ALT+TAB because the rendering with SDL2/DirectDraw isn't possible in this case !
SAVE SCREEN : reworked all the code to work with all video driver and based now to the cpc screen pixel and not the screen visual or dimension
2020/10
WINDOW: Mouse grabbing on main window is disabled by default
ARGS: Added the possibility of enabling mouse grabbing on main window
SCREEN: the heigth of the full screen is now proportional of width factor
2020/09
XPR: Added the Extended Memory Cartridge format with help of Roudoudou ;-)!
MEM: Added the Extended Memory Cartridge format with help of Roudoudou ;-)!
Optimized the memory access using logical bank access switch like GA and ASIC do in real hardware
ARGS: Added the possibility of disabling mouse grabbing on main window
Enjoy :biere: !
Version Windows et Ubuntu Linux 64.
20201115_CPCEPower_SDL_Release_x64.zip
20201115_CPCEPower_SDL_Release_Linux_x64_SDL2_0_12.zip
Une version pour Raspberry PI4 (Raspberry OS / Rasbian) est prévue pour demain normalement !
