Nous sommes actuellement le 18 Août 2026, 19:30
[EMU] Retro Virtual Machine
 [ 5 message(s) ]
 Sujet du message : [EMU] Retro Virtual Machine
Message Publié : 10 Juil 2019, 15:51
The ZX Spectrum and Amstrad CPC emulator for MacOs, Linux and Windows.
v2.0 BETA-1 R7 10/07/2019
* UPD765 Fix the format track overflow bug. Thanks to Francisco González for the report.
* CPC6128 Fix the partial decoding of the IO port of the PAL chip. Thanks to Thomas Bressel for the report
* UI Fixed that the emulator hangs when there are a "unknown" ;) machine in the machine.lson startup file
* MACOS The App is "notarized" by Apple now!!!!, ahead of the macOs 10.15 Catalina requirements
v2.0 BETA-1 R6 06/04/2019
* DSK Prevent the emulator from hanging when opening ZX Spectrum Driller +3
* APP Prevent the application from not opening if there is a problem with the options file.
v2.0 BETA-1 R5 30/01/2019
* Assembler Fixed a bug in the parser that prevented to emit the opcodes "im 1" "im 2" and "im 0".
* Tape When a new tape is created, it is unprotected against writing by default.
* Tape Changed the sense of the write-protect switch to be in line with the floppy drive one.
* Windows The top bar did not hide itself if the task explorer was open especially in Windows 7.
* +3E Corrected the wrong icon of the +3E.
* Amstrad CPC Adjusted the tolerance to the H-Sync in the monitor so that the first screen of One Screen Colonies works (without breaking Darkman).
* ZX-Uno Fixed bug that caused DMA not to work properly in turbo modes.
v2.0 BETA-1 R4 15/01/2019
* GAMEPAD Deleted SAVE configuration option that still has no use
* BUG Correctly encode, decode strings containing characters " and ' in option files
* BUG Fixed that the application will not open if there is an error in the options file.
v2.0 BETA-1 R3 13/01/2019
* Debugger Changed the colors of the flags in the cpu window for more clarity
* Debugger Fixed bug that prevented to add a breakpoint in the last four lines of the cpu view.
* DSK/HFE Fixed bug introduced shortly before the beta R0 that caused that some games will not load correctly
* UPD765 Fixed bug in the behavior of the status register, Goody now loads correctly
* Amstad CPC Adjusted cassette motor delay, Goody on CDT now load correctly
* MacOs Fixed bug that caused the emulator to hang when resizing a window from code. The text size change buttons in the memory and disassembled windows work again.
v2.0 BETA-1 R3 09/01/2019
* CLI Fixed the boot delay in the ZXUno, now the command -c works correctly.
* WINDOWS Fixed keyboard bug, ALT Right key works again
* LINUX Fixed keyboard bug
* TAP Fixed bug that could cause the emulator to crash when loading a corrupt file
* UI Corrected the order of the registers C,E,C' and E' in the debugger CPU window
* UI Fixed some typographical errors in the names of the acknowledgements
* CPC Dandanator Followrom mode fixed
* ZXUno The timex MMU was not activated if port #7ffd was activated.
* SDSPI Implemented the "busy" after a writing. This fixes the ".mkdir" command of ESXDOS 0.8.6 and greatly increases the writing speed in SD.
* z80 Fixed the behavior of the R register while a HALT is running
* UI Fixed several typographical errors
* UI Prevent the main animation from being "transparent" to the mouse
* TAPE Hiding the write protection switch by default, the emulator would hang if pressed without tape
* UPD765 Fixed a bug that could hang the emulator if too many consecutive "seek" or "recalibrate" commands are launched.
* ZX Spectrum Bug in the ZX16k fixed that could cause a hang of the entire emulator
* LINUX X86 Optimization for Intel Core 2 disabled, this version now runs on older computers.
v2.0 BETA-1 R1 27/12/2018
* [UI]: Fixed bug that could cause a general crash when opening a popup
* [Amstrad CPC]: Fixed CRTC bug when r1>r0
* [ZX Spectrum]: Fixed the timing of the AY-8912 in the ZX Spectrum.
* [CLI]: Fixed media loading on ZX.
* [CLI]: Machines make a Hard-reset before starting, this makes that now work well the ZX-Uno and the Inves in the cli
* [CLI]: Fixed bug if trying to load a snapshot that doesn't exist
v2.0 BETA-1 R0 22/12/2018
* First public release
url/src: https://www.retrovirtualmachine.org/
 Sujet du message : Re: [EMU] Retro Virtual Machine
Message Publié : 30 Déc 2022, 18:35
RetroVM v2.1.0 (30/12/2022)
New Features
  • MacOs Version universal (Intel / Apple Silicon)
  • App optimized to work on HiDPI displays (4k, retina display) on MacOs, Windows and Linux
  • Tape counter
  • Zip files support and zip with multiples files support
  • New overlay effect
  • New LCD on the overlay
  • New blur background effect
  • Keyboard support for joystick emulation
  • New audio engine using miniaudio
  • The app no longer uses SDL
  • Rewrited from scratch Amstrad CPC emulation, significantly faster
  • CRTC-0 and CRTC-1 Selectable in Amstrad CPC machines
  • ESXDOS Rom selectable in divmmc and zxuno
  • Support for changing internal ROMs in ZX Spectrum machines
  • Improved effects on the audio panel
  • New machine icons and flags
  • Reducd input lag
  • Reduced frame tearing
src/url: https://www.retrovirtualmachine.org/
Message Publié : 28 Fév 2023, 16:12
RetroVM v2.1.5 (27/02/2023)
  • Fix sound after load a state in the ZX Spectrum Machines
  • Fix HDF file support
  • Fixed the category image for the Microdigital Machines
  • Fix RVM Hangs when no space left in the explorer window of a cpm disc.
  • Fix the timing of the out and in opcodes in the z80 (was incorrect in all the v2.1.x releases)
  • Fix some artwork
RetroVM v2.1.4 (18/01/2023)
  • Possible fix for a bug that caused RVM not to open on Mac if RVM v2.0 had been used before.
  • Machine sounds (cassette, disk, etc) respond to the main volume of the emulator now.
  • Implemented the differences in the 0x3f port of the Japanese Master System.
  • Implemented sprite zoom bug in Master System I VDP
RetroVM v2.1.3 (05/01/2023)
  • Fixed XMEM when adding it to any Amstrad Plus.
  • Fixed a race condition that could occur when flashing a Dandanator CPC.
  • Fixed the Multiplay on Windows and Linux.
  • Added a submessage to the notification when a gamepad is connected with the device name (to facilitate debugging)
RetroVM v2.1.2 (03/01/2023)
  • Added a new machine ‘GX-4000 with 128k Mod’
  • The ‘P’ key functions as a pause again in the Sega Master System and the Sega SG-1000.
  • In the NTSC SMS2, the SMS2 image is now correctly displayed instead of the SMS1 image in the cartridge panel.
  • Fixed the port DFXX in the GX4000
  • Mapped the GX4000 pause button to the P key and the ESC key
  • Mapped alternatively the pause NMI button to the ESC key in the SMS and SG-1000
  • Enabled the ‘-ns’ no shader CLI switch
  • Copyright adapted to the new year!
RetroVM v2.1.1 (31/12/2022)
  • Fixed, the emulator will hang when inserting a disk in drive B of any Amstrad CPC
  • Added a message to warn that the emulator must be restarted when adding firmware to the firmware Vault
  • Added a message to the joystick emulation notification, with the keys that are used
url's: https://www.retrovirtualmachine.org/
https://www.patreon.com/retrovirtualmachine
Message Publié : 25 Juil 2023, 17:22
RetroVM v2.1.7 (24/07/2023)
  • Fixed a bug that occurred when launching the emulator on a secondary screen in MacOS.
  • Fixed a bug that prevented reading and writing correctly on SD cards larger than 4GB, with the error being more severe on Windows.
  • More work on the timings of the TKs (Still not 100% accurate).
RetroVM v2.1.6 (01/03/2023)
  • Adjusted the playback speed of the cassette on the MSX, ZX 128k, and all Microdigital computers, which was 2% faster than normal (yes, I have users with very keen ears ;) )
  • Removed the annoying debug screen in Windows
  • Some adjust to the Microdigital ULA contention (Not perfect yet)
mrmagic
Message Publié : 29 Juil 2024, 23:47
Message(s) : 17
Bonjour Pas de version android? Dommage :-|
 [ 5 message(s) ]
