Nous sommes actuellement le 09 Sep 2026, 09:13
[EMU] Caprice Forever (Fredouille)
 Sujet du message : [EMU] Caprice Forever (Fredouille)
Message Publié : 31 Mars 2017, 07:18
Message(s) : 3693
Beta Release 17.3, 17 March 2017
  • Preliminary SNR session playback;
  • Insert Caprice32 FDC engine as fast FDC;
  • Add support for DualShock 4 wireless controller;
  • Preliminary text rendering for DMP2160 Dot Matrix Printer;
  • Add scripts to help entering cheat modes;
  • Add keyboard clash phenomenon ("Ghosts" keys);
  • Add CPC 664 french machine (different hardware keyboard than UK);
  • Add recent disk images list;
  • Add favourite disk images list;
  • Add display option to keep fullscreen for next session;
  • Use custom patterns for scanlines (see Hints);
  • Add option to never update disk images;
  • Fix minor bugs.
Beta release 0.30, 19 December 2016
  • Fix FDC engine to pass most of Kevin Thacker's 'acid' tests;
  • Add option to cold reset at real speed (see Hints);
  • Load disk and tape images from ZIP archive file;
  • Add disk menu to manually update and reload disk image;
  • Add popup menu for direct disk drive function access;
  • Fix Tape to load "The Last Mission";
  • Fix minor bugs.
url: https://cpcrulez.fr/emulateurs_download- ... orever.htm
 Sujet du message : Re: [EMU] Caprice Forever (Fredouille)
Message Publié : 22 Mai 2017, 12:07
Message(s) : 3693
    Beta Release 17.5, 19 May 2017
  • Add cheat script keywords;
  • Fix FastFDC crashes when trying to read multi-sided disk image;
  • Play CSW tape images;
  • Convert WAV to CSW tape images (see Hints);
  • Fix game controller detection issues (Xbox 360);
  • Fix FDC write sector issues;
  • Fix FDC read sector regression (Dimension6);
  • Use "Keep original aspect ratio" option for fullscreen display;
  • Add PlayCity audio channels;
  • Fix minor bugs.
src/url: http://www.emu-france.com/emulateurs/10 ... d-cpc-cpc/
 Sujet du message : Re: [EMU] Caprice Forever v17.11 (Fredouille)
Message Publié : 30 Nov 2017, 16:31
Message(s) : 3693
Beta Release 17.11, 17 November 2017
- Fix FDC engine to pass most of Kevin Thacker's New 'acid' tests:
- write sector with wrong cylinder;
- write sector with bad cylinder;
- Fix FDC engine to pass old Kevin Thacker's 'acid' tests for Amstrad CPC 6128 only;
- Load disk and tape images inside ZIP from menu;
- Update fullscreen dialog windows;
- Add AMX Mouse simulation;
- Improve support of second joystick;
- Add display option to reduce text during pause;
- Add dialogs GUI skin customization;
- Fix minor bugs.
src: http://www.gametronik.com/site/emulation/amstrad/
Message Publié : 13 Avr 2018, 07:45
Message(s) : 3693
Beta Release 18.4, 7 April 2018
- Fix CRTC regression with "Turrican" but involving issues with "iMPdraw";
- Add Audio Speaker and PlayCity Line OUT or Internal option;
- Add Audio PlayCity invert channels option;
- Fix FDC regression to load "The Real Ghostbusters";
- Add Graphics explorer and Tile editor;
- Drop ROM file for testing purposes;
- Fix minor bugs.
- Fix minor bugs.
Message Publié : 18 Juil 2018, 17:26
Message(s) : 3693
Beta Release 18.7, XX July 2018
- Fix Z80 instructions display;
- Fix theme display at first launch;
- Fix minor bugs.
Beta Release 18.6, 2 June 2018
- Fix CRTC regression with "iMPdraw";
- Fix VDU regression with "ThunderBlade";
- Improve CRTC type 1 emulation;
- Add VDU V-HOLD adjust for correct iMPdraw display;
- Fix minor bugs.
Message Publié : 18 Juil 2018, 21:42
Oups
Message Publié : 24 Mars 2019, 15:46
Message(s) : 3693
Beta Release 19.3, 19 March 2019
- Fix FDC read failure detection;
- Fix FDC regression to load MegaBlasters;
- Upgrade Graphics Explorer GUI;
- Improve Memory Editor;
- Preliminary CT-RAW image disk read;
- Add 4M RAM expansion;
- Add Digiblaster audio channel;
- Fix minor bugs.
url/src: http://www.gametronik.com/site/news-297 ... _v193.html
velus
Message Publié : 24 Mars 2019, 16:20
Message(s) : 230
J'ai l'écran qui reste noir ! Si je fais del j'entends le bruit du curseur qui efface.
Faut-il installer des roms ? Comment ? J'ai joint le fichier debug. Merci
Fredouille
Message Publié : 25 Mars 2019, 14:19
Message(s) : 174
Est-ce la première fois que tu lances Caprice ?
Par défaut, la configuration est 6128 UK.
Peux-tu essayer avec OpenGL ? (Option UseOpenGL=1 dans le fichier Caprice.ini).
Si cela ne marche pas, peux-tu essayer en GDI ? (Option ForceGDI=1 dans le fichier Caprice.ini)
velus
Message Publié : 25 Mars 2019, 15:27
Message(s) : 230
Ca marche bcp mieux comme ça! Merci :)
Message Publié : 10 Juil 2019, 10:59
Message(s) : 3693
Beta Release 19.7, 6 July 2019
- Update overall GUI;
- Free CPU resources;
- Fix CRTC1 display with "Post Scriptum" demo;
- Fix FDC problem when using ProCopy;
- Fix 4M RAM addressing issues;
- Add files manager for direct operations with Windows;
- Fix minor bugs.
url/src: http://www.emu-france.com/emulateurs/10 ... e-forever/
Message Publié : 07 Oct 2019, 17:41
Message(s) : 3693
Beta Release 19.10, 5 October 2019
- Increase full speed;
- Improve assembler compilation using Pasmo;
- Add breakpoint on Read/Write memory accesses;
- Fix minor bugs.
Message Publié : 02 Mars 2020, 20:47
Message(s) : 3693
Release 20.2, 28 February 2020
- Add files extension registration;
- Add Disk and Tape fast loading feature;
- Add ROMDOS D1 disk format support for files management;
- Improve split rasters display;
- Fix minor bugs.
src/url: http://www.gametronik.com/site/news-310 ... _v202.html ;linked:
Message Publié : 12 Oct 2020, 16:36
Message(s) : 3693
Release 20.10, 11 October 2020
- Add Action Replay to filter RAM memory content;
- Audio devices list review;
- Fix some keyboard issues with CTRL key;
- Fix crashes when CSW tape is inserted;
- Fix autotype issues in hardware mapping mode;
- Improve PPI emulation using Arnold PPI tests;
- Improve Input/Output decoder with PPI settings;
- Fix minor bugs.
Release 20.7, 14 July 2020
- Patch Pasmo assembler to accept "EX HL,DE";
- Allow up to 32 upper roms;
- Add Memory Editor differences highlighting;
- Allow unlimited breakpoints;
- Fix crash at joystick removal;
- Fix FDC head position after stepping;
- Detect AMSDOS header when loading ROM;
- Support X-MEM memory expansion;
- Fix minor bugs.
Release 20.5, 8 May 2020
- Adaptation for Win64 platform;
- Change lightguns and AMX mouse shortcuts;
- Add direct shorcut for custom speed turbo;
- Add access to main display size zoom factor;
- Autotyping at full speed;
- Patch Pasmo assembler to accept "OUT (C),0", "SBC N", "ADC N", "ADD N";
- Fix FDC Wrong Cylinder and Bad cylinder flags issue;
- Fix minor bugs.
Release 20.3, 25 March 2020
- Fix some Z80 instructions timings;
- Fix color issue when loading snapshot;
- Fix minor bugs.
src/url: http://www.emu-france.com/emulateurs/10 ... r-32-bits/
Message Publié : 01 Avr 2022, 18:45
Message(s) : 3693
Release 22.4, 1 April 2022
- Improve Amstrad PLUS ASIC emulation;
- Update some Z80 instructions behaviours;
- Almost all keyboard shortcuts are configurable;
- Fix minor bugs.
Release 21.11, 11 November 2021
- Improve FDC Read ID function using accurate timings;
- Introduce preliminary support of Amstrad 6128 PLUS model;
- Show monitor boundaries;
- Fix minor bugs.
Release 21.6, 23 June 2021
- Improve loading of CDT tape files;
- Improve CDT conversions;
- Add Tape counter;
- Support direct binary file load and execution;
- Improve CRTC behaviour using Kevin Thacker tests;
- Fix multi-origins assembler compilation issue using Pasmo;
- Fix minor bugs.
Release 21.4, 1 April 2021
- Add Z80 instructions Trace;
- Add CDT converter to CSW and audio WAV;
- Fix minor bugs.
Release 21.1, 8 January 2021
- Add Multiplay Mouse emulation;
- Add cursor capture option to improve mouse emulation;
- Support X-Mem SST flash memory;
- Add Simple Poke Window;
- Fix minor bugs.
Release 20.12, 6 December 2020
- Remove Taskbar to Win32 release to keep compatibility with Windows XP;
- Support X-Mass storage peripheral;
- Remove X-Mem "Free" button;
- Improve breakpoints to filter lower and upper roms;
- Speed-up emulator shutdown;
- AMX Mouse emulation review;
- Add Symbiface Mouse emulation;
- Fix minor bugs.
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 62 invité(s)
