| [EMU] WinAPE v2.0b2 https://cpcrulez.fr/forum/viewtopic.php?f=7&t=5650 |
Page 1 sur 1 |
| Auteur : | Princesse Mariana [ 05 Jan 2016, 07:57 ] |
| Sujet du message : | [EMU] WinAPE v2.0b2 |
Citer : Emulation - Correct Z80 Flags emulation for IN and OUT and all derivatives. - Added support for CRTC Type 1 register 6 border blanking when set to zero. Debugger - Changed breakpoint conditions to use 32 bit values rather than 16 bit values. - Added a number of functions to breakpoint conditions to support 32 bit to 16/8 bit conversion. - Added true and false variables. Assembler - Added ability to load symbols from the WinAPE command line using the /SYM:filename parameter. - Option to automatically hide the output window on successful assemble. Other - Added documentation of command line parameters in help files. - Added documentation of new breakpoint condition variables and functions. - Updates ParaDOS 1.2 and ParaDOS 1.2+ ROM images to bug-fixed version which will work in slots below 7. src/url: http://www.winape.net/ |
| Auteur : | TotO [ 05 Jan 2016, 09:05 ] |
| Sujet du message : | Re: [EMU] WinAPE v2.0b2 |
Enfin, Parados fonctionne sur autre chose que la ROM7 ! Comme quoi... Un patch du soft vaut mieux qu'un hack du CPC.
