Pas grand chose en actu émulation en ce moment... a part une update de JOYCE (emulateur PCW sous unix/win32/macosx)
Update History 2014-10-08 : JOYCE v2.2.7 (stable) released. This contains code to guard against the possibility of a malicious CP/M program overwriting or deleting important files on the host computer or crashing JOYCE. If you use JOYCE / ANNE to run CP/M programs downloaded from the Internet, I recommend that you upgrade to this version. 2012-10-24 : JOYCE v2.2.5 (stable) released, with compilation fixes for the latest version of libpng, and a fix for a crash in the native VGA driver. 2010-11-03 : JOYCE v2.2.4 (stable) released. Improvements to keyboard emulation; some compiler warnings removed, and an updated SDL.DLL included with the Windows version. 2010-06-09 : JOYCE v2.2.3 (stable) released. This has a further correction to the configuration script. 2009-11-08 : JOYCE v2.2.2 (stable) released. This corrects some compilation issues on recent Linux systems.
2016-04-16 : JOYCE v2.2.10 (stable) released: compilation fixes for recent GCC versions. Since these only apply to Linux source builds I haven't done a new Windows pack. 2016-04-16 : JOYCE v2.2.9 (stable) released. This adds emulation of the Electric Studio light pen.
2021-01-07 : JOYCE v2.2.14 (stable) released: Fixes autodetection of extended DSK files, display artefacts when colours are changed while video is disabled, and Rosanne checksum detection when the ROM is patched. 2019-06-29 : JOYCE v2.2.13 (stable) released: fixes compilation on recent Unix distributions. Since this only applies to Linux source builds I haven't done a new Windows pack. 2017-07-07 : JOYCE v2.2.12 (stable) released: the default keyboard mapping for the # and \ keys under Windows has been corrected. 2017-02-12 : JOYCE v2.2.11 (stable) released: added a feature allowing up to 13 emulated hard drives in CP/M (rather than 5-6 as in previous versions). Also corrected the build process so LyX is not required.
2023-02-19 : JOYCE v2.5.1 (development) and 2.4.1 (stable) released. Fixes for parallel port emulation within ANNE. 2022-08-03 : JOYCE v2.5.0 (development) released. Adds support for running CP/M-86 or CP/M 2 as guest sessions inside PCW CP/M. 2021-12-14 : JOYCE v2.4.0 (stable) released: Fixes an issue where PIP would hang copying 16k-32k files on folders mapped as drives.
