Nous sommes actuellement le 09 Sep 2026, 06:30
[EMU] JavaCPC Desktop official release
 [ 31 message(s) ]  Aller vers la page 1, 2, 3  Suivant
Devilmarkus
 Sujet du message : [EMU] JavaCPC Desktop official release
Message Publié : 13 Août 2011, 14:51
Message(s) : 20
JavaCPC Desktop is a brand new Amstrad CPC emulator.
It is based on JEMU (http://sourceforge.net/projects/jemu)
and is an extremely improved release from JavaCPC 6.7.
JavaCPC Desktop is designed to be used on Windows systems only,
but maybe can run also on other systems, but a few features will be missing then.
JavaCPC is no freeware any longer!
It's new license is "Donationware".
What does this mean?
- JavaCPC and all of it's contents are free, and are allowed to be shared.
- It's available sources are not complete but you are allowed to use them.
- If you register JavaCPC, please also think about a little donation.
(JavaCPC consumes much time in it's development)
- The only legal downloadplace is: http://sourceforge.net/projects/javacpc/
or also http://cpc-live.com
- Other people who wants to offer JavaCPC on their own webpages, please contact me
under webmaster@cpc-live.com
What is new, what can I expect as a JavaCPC 6.7 user?
JavaCPC Desktop is a completely rewritten emulator, which offers you a big spectrum of apps and tools.
It comes with it's own desktop!
The tools and apps:
- Integrated Z80 Assembler: Feel free to create your own programs in Z80 Assembler. Compile them directly into the CPC's ram.
- Improved Debugger
- Virtual Keyboard: You cannot find your key you need? Use the virtual Keyboard then.
- Alarm Clock: A simple alarm clock, which reminds you when you have something else to do.
- YM-Control: Record and playback your own YM files.
- Manage DSK (Windows only!): Copy files from your PC on a DSK or vice versa.
- Audio Capture: Record your favourite CPC sound as WAV file.
- TapeDrive: A fully controllable virtual tape drive. Supports CSW, CDT, WAV and MP3
- JavaCPC Paint: Paint your own screens in normal mode or also as Overscan pictures. Convert existing images to CPC format.
(Supported import-Formats: PCX, TGA, BMP, PNG, GIF, JPG, SNA)
- Mandelbrot: A simple app to paint Mandelbrot fractals directly on the CPC screen.
- Tiled Mapeditor: You can use it to create game maps etc...
- Poke Finder: A simple tool to find PEEKS and POKES to cheat in games.
- Calculator: A scientific calculator which understands string input with brackets etc...
- WebBrowser: A webbrowser
- GameBrowser: Don't waste your time by downloading hundreds of CPC games without checking them! Just load them directly into the emulator and play them.
- Virtual Floppy: A little thingie to see what your virtual disc drive does.
- SubPopRadio: Listen to the best CPC-tunes available in WWW!
- JavaCPC Chat: Chat with other JavaCPC users all over the world. (Experimental)
- Favourites: Add and load your favourite DSK, CDT or SNA files with a few mouseclicks only!
- DSK2CDT: Simple filetransfer to copy files from an existing DSK file on a new CDT file (Windows only!)
- And much more!!!
Further questions?
Feel free to contact me @ webmaster@cpc-live.com
Download:
Here.......
The tools and apps:
- Improved Debugger
- And much more!!!
Further questions?
Download:
[b][url=http
 Sujet du message : Re: JavaCPC Desktop 1.0 official release
Message Publié : 13 Août 2011, 19:10
Seems Amazing...
Unfortunely this don't work on my WinXP Desktop ! The basic always reset and I can't do anything on the emulator window !
I hope you will fix it soon ! :biere:
Devilmarkus
Message Publié : 13 Août 2011, 20:21
Message(s) : 20
Megachur a écrit :
Seems Amazing...
Try this:
Look into C:\documents and settings\your_username\JavaCPC\
and delete ALL files inside this folder...
Make sure you use 32bit Java...
Message Publié : 15 Août 2011, 12:20
JavaCPC Desktop correspond a une version complètement réécritre de JavaCPC. Il arrive avec son propre bureau et des applications intégrées.
- Intégration d'un assembleur Z80.
- Amélioration du débogueur.
- Clavier virtuel.
- Une horloge qui fournit une alarme.
- Un contrôle YM : lecture et enregistrement de vos propres fichiers YM.
- Gestionnaire de fichier DSK (Windows uniquement).
- Capture du son : enregistrement des sons du CPC dans un fichier WAV.
- Lecteur de cassette qui supporte les formats CDT, CSW, WAV et MP3.
- JavaCPC Paint : dessinez vos propres écrans dans le mode normal ou dans un mode avec sur-balayafe. Conversion des images dans le format CPC (support des formats PCX, TGA, BMP, PNG, GIF, JPG, SNA).
- Mandelbrot : un application qui dessine des fractales de Mandelbrot.
- Tiled Mapeditor : créer des cartes pour les jeux...
- Poke Finder : outil pour trouver des codes triche PEEKS et POKES.
- Une calculatrice.
- Un navigateur Intenet.
- Un Explorateur pour les jeux : ne perdez pas votre temps à télécharger des centaines de jeux CPC sans rien vérifier. Chargez les simplement directement dans l'émulateur et jouez.
- Disquette virtuelle : permet de voir ce que fait votre lecteur de disque virtuel.
- SubPopRadio : écoutez les meilleures musiques CPC disponibles sur le WWW.
- JavaCPC Chat : discutez avec les autres utilisateurs de JavaCPC (expérimental).
- Favoris : ajoutez et chargez vos fichiers DSK, CDT, SNA favoris en quelques clics de souris.
- DSK2CDT : transfert de fichier pour copier les fichiers contenus dans un fichier DSK vers un nouveau fichier CDT (Windows uniquement).
- ET encore plus.
Devilmarkus
Message Publié : 17 Août 2011, 14:27
Message(s) : 20
JavaCPC 1.0b is an additional update.
You can install it from JavaCPC's menu: "Help -> Check for updates".
What's new?
- Java Joystick library added. Should work with your gamepad now.
When done, it asks you for the 2 fire-buttons.
Press them on your joypad in order.
To reset this settings, use menu: "Settings -> Reset Joystickbuttons"
It's important that you have the joystick translation enabled and that you don't use the "Alternative Joystick control".... (This is set properly by default!)
Devilmarkus
Message Publié : 17 Août 2011, 20:03
Message(s) : 20
BUG alert! Please (If your JavaCPC still starts up) let it check for updates again!
If it quits and you don't know why, run Update.jar (Or put a .bat file with content: "java -jar Update.jar" (without "") into your JavaCPC folder)
Devilmarkus
Message Publié : 25 Août 2011, 22:20
Message(s) : 20
Major release to version 1.1!
Many bugs (which had not been reported during the beta-phase) were the reason why I decided to release version 1.1 today.
What has changed?
- Z80 emulation core improved. MEMPTR register fully emulated now,
some small bugs fixed.
LDI, LDD fixed.
- JavaCPC Paint: Many bugfixes and improvements.
- Debugger: MEMPTR register info and IM status added.
- YM Player overhauled
- JavaCPC Expansion ROM updated
- Joystick libraries and joypad emulation added.
- Replaced annoying dialog when drag & drop is used to load a DSK
- Display improvement for SuperPAL filter (faster now)
- Logic bugfixes in emulation core
- several smaller bugfixes
- PPI bugfix (Storing of SNA fixed and also PPI info in debugger is correct now) Thanks to TFM for finding this bug!
Download:
http://cpc-live.com/javacpc/list.php?dir=Release
Or use the update function... But: users, who want to use JavaCPC expansion ROM should update this ROM, too:
http://cpc-live.com/javacpc/list.php?di ... sion%20ROM
Message Publié : 05 Déc 2011, 23:38
Depuis aujourd'hui le site émule la machine Amstrad CSD (Cartridge Software Demonstrator). Il s'agit d'un appareil de démonstration fourni aux vendeurs pour promouvoir les jeux GX-4000. Son architecture comprenait une carte mère d'un Amstrad CPC 464+ et disposait de 12 emplacements pour enficher autant de cartouches GX-4000.
url : http://java.cpc-live.com/csd/index.php?csd=true ;linked:
Message Publié : 09 Fév 2012, 22:30
JavaCPC Desktop 1.5
- La palette est restaurée maintenant lorsque vous charger une capture.
- Le chat changement maintenant pour un chat php (le même que sur java.cpc-live.com).
- L'affichage 3D accepte maintenant le glisser-déposer.
- Gamebrowser update : il affiche les jeux sur java.cpc-live.com (les démos sont également disponibles).
Message Publié : 12 Mai 2012, 19:40
JavaCPC Games :
- L'émulateur a changé et devrait démarrer de manière un peu plus fluide.
- Ajout de beaucoup de jeux, il y a maintenant 1 000 titres disponibles en ligne.
- Amélioration de la fonction de recherche. Possibilité de chercher plusieurs jeux dans une seule recherche, n'oubliez pas de séparer les mots par une virgule.
- Les 10 derniers jeux et 10 dernières démos sont affichés en bas de la page d'accueil du site.
- Il y a maintenant 13 jeux dans la section highscore.
JavaCPC Desktop 1 Update 6a :
- Amélioration de l'assembleur intégré Z80.
- Légère modification de l'émulation AY.
- Ajout de nouvelles commandes internes
create_dsk "a:mydisk.dsk",data,40 -> création d'une image de disque vierge dans le lecteur DF0. Formats disponibles : data, system, 40 ou 80 piste.
add_loader "myloader.bas" -> création d'un petit chargeur BASIC pour les fichiers que vous voulez assembler.
write direct "a:myfile.bin" -> écrire un programme assemblé en DSK dans le lecteur donné.
Message Publié : 29 Juin 2012, 06:23
JavaCPC Desktop 1.7b
- Correction du clavier germanique.
- Correction d'un bogue qui désactivait les ROMs lorsque vous activiez le panneau-de-statut.
- Correction d'un bogue qui faisait que les ressources externes n'étaient pas copiées dans C:\Users\\JavaCPC de telle sorte que les Apps internes ne fonctionnaient pas.
 Sujet du message : Re: [EMU] JavaCPC Desktop 1.0 official release
Message Publié : 24 Nov 2012, 05:19
Attention, la mise à jour actuelle est uniquement disponible via la fonction de mise à jour du programme :
- ouvrir JavaCPC
- aller dans le menu "Help" -> "Check for Update" et suivre les messages.
1.8 :
- Ajout de commandes RSX qui permettent de copier un texte ou d'autre fichier dans l'écran :
|TYPE,"
et
|HEXTYPE,""
1.7f :
- Ajout d'un système de fichier interne à JavaCPC (activer simplement la "JavaCPC expansion ROM").
- Changement de la gestion des ports pour "JavaCPC expansion ROM" (pour éviter des interférences avec Digiblaster).
1.7e :
- Nettoyage du code.
- Tous les messages en texte sont directement envoyés via le CPC émulé.
- Il n'y a plus de stupide -chars.
1.7d :
- Correction : gestion du bit SPARtan dans FutureOS.
- Nouveauté : fonction Détacher / Attacher dans le panneau intégré sur le bureau.
Message Publié : 16 Fév 2013, 16:07
JavaCPC v1.9 is ready:
- Debugger -> Added a simple BASIC-debugger.
- CPC-Screen-To-ASCII feature implemented. (You'll find it in menu -> Edit or by pressing shift+F11)
Devilmarkus
Message Publié : 08 Mai 2013, 14:58
Message(s) : 20
JavaCPC Desktop 2.0a is out!
Because of lacking time and motivation, I decided to roll-out version 2.0a.
What is new?
- Built-in "direct font editor" -> you now can edit the system rom's font. (It also opens a user defined font)
You can also store modified fonts as headerless binary or into a new lower-OS-ROM file.
Press ALT + F11 to open it. (Or check in menu -> Edit -> Open Font Editor)
- A wallpaper is set by default now. 4 wallpapers are available now. (1920x1080 pixels) You of course can also set your own wallpaper.
- The menubar now also shows up, when desktop is "Expanded"
What has changed?
- Several minor bugfixes.
- Bugfixes in the internal paint application
- Rewritten code to posterize images (Turn your favourite photo/image into a CPC-pixelized image keeping the original proportions)
- Internal java console is now turned off by default. (You can still enable/disable it in the preferences)
You can run an update or download 3 different files:
- JavaCPC_Desktop_2.0a.zip -> Complete emulator in a ZIP archive
- JavaCPC_2.0a_Setup.zip -> Complete emulator as a setup file
- JavaCPC_Desktop_Online_Setup.zip -> Only the online installer, put it somewhere you want to install JavaCPC inside, and launch it.
For those of you, who run the update:
- When the update runs first time, the updater self-closes.
- Launch JavaCPC.exe again then, and a 2nd update starts, which updates the Update.jar itself and also the last required files.
This happens, because in this release, the updater changed, too.
You can find the files here:
http://cpc-live.com/data/index.php
Have fun!
 Sujet du message : Re: [EMU] JavaCPC Desktop 2.0a official release
Message Publié : 17 Mai 2013, 22:30
update pour cette version v2.0a
Nouveautés :
- Nouvel outil intégré "direct font editor" : possibilité de modifier la police de caractères des roms.
- Un fond d'écran est maintenant réglé par défaut. Il y en a 4 de disponibles. Possibilité de mettre votre propre fond d'écran.
- Affichage de la barre de menu, lorsque le bureau est "Expanded".
Modifications :
- Divers correctifs mineurs.
- Correctif dans l'application interne Paint.
- Réécriture du code pour postériser les images.
- La console interne Java est maintenant coupée par défaut.
src/url: http://cpc-live.com/data/index.php ;linked:
