Nous sommes actuellement le 17 Août 2026, 16:57
SAMDISK v3.0
 Sujet du message : SAMDISK v3.0
Message Publié : 22 Juin 2010, 04:10
SAMdisk is a command-line disk image utility for Windows 2000 or later.
The utility supports transfers between floppy disks and disk images, and is designed to work with almost any soft-sectored disk format compatible with the PC floppy controller, including some copy-protected formats.
Low-level floppy device access requires the fdrawcmd.sys driver to be installed.
changelog:
Version 3.0 (2010-06-20)
- Largely re-written again, for non-uniform track support
- Added +3 protections: Speedlock weak sectors, OperaSoft 32, various motor bug fixes
- Added CPC protections: Speedlock/EA weak sectors, Infogrames/Loriciel gaps, KBI-10, KBI-19
- Added support for many disk image containers, including EDSK, TD0, DMK, IPF
- Added support for zip, gzip and bzip2 archives using zlib1.dll and bzip2.dll
- Added directory support for MGT, TR-DOS, Opus, Didaktik and Amstrad CP/M
- HDD support for drives up to 2TB, with improved lock/dismount and safety checks
- Changed to Unix-style getopt for command-line options
- Removed embedded fdrawcmd.sys driver
url : http://simonowen.com/samdisk/ ;linked:
 Sujet du message : Re: SAMDISK v3.0
Message Publié : 22 Juin 2010, 07:55
Message(s) : 635
Great !!!
Ce programme est vraiment au top, les protections KBI passent comme une fleur :)
