The Caprice Reloaded emulator, with integrated assembler and debugger.
Installation under Windows for v0.304
As of now, there is no automated setup, so here are some hints : Most of the data is stored in Document and settings/your_user/application data/reloaded/ In this folder you need Keymap.cfg, and a folder called roms with the roms you want to use (usually cpc6128.rom and amsdos.rom, but you can add more). That should set you up, you can place all the other files anywhere on your harddisk.
r320 est dispo...
* IPC system to load a dsk or snapshot into an already running instance of Caprice from an external command line.
* Backport z80 fixes from Mame 3.9. Should fix OUTI/INI§/IND/OUTD/INIR/OTIR/OTDR/INDR, and BIT undocumented flags behaviour. Stil failing on ADD IX,reg16 test, I can't spot the problem... * [bugfix] Correct an error in the ROM gestion: - segfault when no ROMs in user dir - instead of reading ROMs in system dir, readin in user dir (and then segfualt when n ROms in user dir) * [bugfix] Uncomment nextSample which is required in order to compile * Fix the disassembler as windows doesn't like having tabs in a listbox * Also work around a bug in windows that prevent getting monospaced fonts * Support for the MEMPTR regiter. Hopefully I got it right. * Render frames to screen only every 50Hz. This still allow climax intro to render but make the screen flipping pictures a lot worse * Remove the now unused exit condition from z80 : psg buffer full * Fix the down key in the keyboard setup * Fix the radio buttons for 50/60Hz and ram size being in the same group
* Render frames to screen only every 50Hz. This still allow climax intro to render but make the screen flipping pictures a lot worse * Remove the now unused exit condition from z80 : psg buffer full * Fix the down key in the keyboard setup * Fix the radio buttons for 50/60Hz and ram size being in the same group.
New version of Reloaded for Windows. * Video rendering should be a little faster * Display a crosshair where the electron beam is in pause mode (a bit inaccurate) * Fix some problems with VBL and jumper settings * Disk editor also works for drive B, so you can copypaste sectors around between two DSKs * Some other small fixes
version r533 est sortie... pas mal de news depuis le dernier build, aller donc faire un tour sur le site google.code pour tout savoir .... url : http://code.google.com/p/cpcsdk/
