Nous sommes actuellement le 19 Août 2026, 15:44
It's Halloween and the new JavaCPC v6.7 is ready!
Devilmarkus
 Sujet du message : It's Halloween and the new JavaCPC v6.7 is ready!
Message Publié : 31 Oct 2009, 19:59
Message(s) : 20
Hi together,
I finished JavaCPC 6.7 just in time.
The new JavaCPC version offers the following changes:
- Improved CRTC 0 and cRTC 1 emulation, fully emulates Registers 6 and 8
- New feature: JavaCPC Paint allows to paint normal sized screens, convert
JPG, BMP, PNG and GIF on-the-fy into CPC format
- Realtime clock (Just for fun, not a real emulated feature, demodisk is
included)
- Performance observer to avoid low performance / bad synchro
- You can dump cpc-ram directly into HEX-Editor now (Read-only,
but saveable to PC)
- LZH uncompression possible for YM files
- improvements for the YM player
- Several minor bugfixes
- Bugfix in Autotype to avoid shift-key ignores
- Changed colour tables for Colour monitor (Linear / Non-linear)
New: JavaCPC Paint - A internal application, which allows you to draw directly into CPC-Screen ram!
You can also convert BMP, PNG, GIF and JPG images directly into CPC-Format...
(Not perfect but works very well, if colours are set bad, adjust brightness a bit)
Download your copy here
Sources are not longer part of the downloads!
If you need sources, you'll find the latest sources always on http://sourceforge.net/projects/javacpc into it's SVN repository.
Have fun with it and a happy halloween!
Markus
 Sujet du message : Re: It's Halloween and the new JavaCPC v6.7 is ready!
Message Publié : 02 Nov 2009, 09:08
- Amélioration de l'émulation des CRTC 0 et CRTC 1. Emulation complète des registres 6 et 8.
- Nouvelle fonction : JavaCPC Paint reproduit les écrans de taille normale, il convertit à la volée les fichiers JPG, BMP, PNG et GIF dans un format compatible CPC.
- Horloge en temps réel (c'est seulement pour le plaisir, disque de démo inclus).
- Observateur de performance pour éviter de mauvaises synchronisations et des performances faibles.
- Vous pouvez copier la RAM du CPC directement dans un éditeur hexadécimal (en lecture seule, mais peut être enregistré sur le PC).
- Décompression LZH possible pour les fichiers YM.
- Amélioration du lecteur YM.
- Divers correctifs mineurs.
