Hi together, I decided to release v.6.6.4 of JavaCPC. It has many improvements and some new features:
- Debugger improvements (Breakpoints, Break Instructions) - Tape polarity changeable (Needed for some strange tapes) - New displaying method allows DoubleBuffered in actual JAVA-update - A virtual floppy drive as anchor window, moveable with mouse and zoomable (Double click with left/right mousebutton into the drive) - Simple GIF-Recorder (Not perfect, but funny) - New screenshot routine (Allows to catch also the filter/monitor mask) - New greenscreen emulation - Improved display filter (needs high performance PC's) - JavaCPC's window position is stored now on exit - Added Prodatron's Digitracker tools as internal applications (MOD converter and Player generator) - CRTC improvements allow the demo "From Scratch" to be viewed fully - Small bugfix in FDC emulation (allows to watch raster images from ConvImgCPC without read error)
For coders, the most useful things will be the new debugger features "Breakpoints" and "Break Instructions"
Break Instruction does the same than WinApe's feature: It stops the emulation and opens the debugger when ED,FF is reached.
"Breakpoints" are already part in older versions, but now you can enable/disable them in debugger window. They are also more exact now. (Strange things happen during z80 cycles ;D )
- Améliorations du débogueur (points d'arrêt, instructions d'arrêt). - Possibilité de changer la polarité des cassettes (nécessaire pour certaines cassettes étranges). - Nouvelle méthode d'affichage permettant la mise en double mémoire tampon. - Un lecteur virtuel de disque comme une fenêtre avec ancrage qui peut être déplacée avec la souris et peut être zoomée (faire un double-clic sur le lecteur). - Enregistrement au format GIF (n'est pas encore parfait). - Nouvelle routine de captures d'écran. - Nouvelle émulation de l'écran vert. - Amélioration des filtres d'affichage (nécessite un PC puissant). - Le programme retient maintenant la position de la fenêtre de JavaCPC à la fermeture. - Ajout d'outils Digitracker de Prodatron en tant qu'applications internes (convertisseur MOD et générateur de joueur). - Améliorations du CRTC, ce qui permet de voir complètement la démo "From Scratch". - Petit correctif dans l'émulation FDC (possibilité de voir les images depuis ConvimgCPC sans erreur de lecture).
