CPC Rulez https://cpcrulez.fr/forum/ |
Arnold Win32 (02-01-2009) https://cpcrulez.fr/forum/viewtopic.php?f=7&t=3475 |
Page 1 sur 1 |
Auteur : | hERMOL [ 02 Fév 2009, 22:14 ] |
Sujet du message : | Arnold Win32 (02-01-2009) |
Citer : jan 2009 -------- - arnold started up with something that looked like a cpc6128 but was cassette based. now fixed. arnold starts with a real cpc6128 configuration. - started to implement a new "load file into ram" option. Not finished yet but I was going to use this to run some tests with arnold. December 2008 ------------- - it was not possible to insert an expansion rom (now fixed). clicking on load button would not do anything. - lots of dissassembly errors fixed. Some instructions were wrong, some were not formatted correctly. Some were inconsistent. - If Arnold failed to auto-start a disc it would not tell you. - If Arnold failed to auto-start a disc it would leave autotype on and would print garbage. Cpc would hang. - If Arnold failed to auto-start a disc it would leave autotype on, reset did not stop it. Cpc would be hung after reset. - Failed to autostart discs where directory had graphics and the only file to run was hidden. - Can now load 256k and 512k snapshots. - Much more tolerant to bad snapshots (bad length). - Can now autostart disc/tape on cpc+. - compressed memory blocks in snapshot v3 are now supported (snapshots written by winape should now load) - disc image filename blocks in snapshot v3 specification are now supported (snapshots written by winape should now load) - scroll lock led no longer reflects drive led. it was not useful because it only reflected the state of the internal drive anyway. November 2008 ------------- Fixes: - Ukonx tracker now loads. - Last Ninja 2 Remix (protected disc image) can now be inserted without Arnold crashing - Natural Bug Killer demo now runs - Inserting some disc images would cause Arnold to crash. - Fixed bug with CPC+ snapshot loading/saving. Some snapshots identify themselves for CPC old generation, but if a CPC+ special block is found it is assumed CPC+ is used. - Fixed a bug in the fdc emulation meaning Natural Bug Killers would hang after intro part. url : http://www.kjthacker.f2s.com/arnold-02-01-2009.zip |
Auteur : | Capitaine [ 12 Fév 2009, 16:20 ] |
Sujet du message : | Re: Arnold Win32 (02-01-2009) |
OH putainn merci ! ![]() Ca fait des années que j'attendais une mise à jour. Le site http://arnold.emuunlim.com avait été piraté mais ce http://www.kjthacker.f2s.com c'est le nouveau site officiel ? J'aimerais bien aussi une mise à jour sur Caprice32... ![]() hERMOL a écrit : Citer : Bon j'ai parlé trop, vite le lien est mort ![]() |
Auteur : | hERMOL [ 12 Fév 2009, 20:59 ] |
je te l'ai mis par la : https://cpcrulez.fr/emulateurs_download ... old.htm#DL |
Auteur : | Capitaine [ 13 Fév 2009, 13:04 ] |
Merci ! ![]() Par contre je viens de voir encore une autre version annoncée sur cpczone.net http://www.kjthacker.f2s.com/arnold-03-02-2009.zip |
Auteur : | hERMOL [ 13 Fév 2009, 20:48 ] |
Nikel, j'ouvre un nouveau topic alors! |
Page 1 sur 1 | Le fuseau horaire est UTC+1 heure |
Powered by phpBB® Forum Software © phpBB Group https://www.phpbb.com/ |
