Nous sommes actuellement le 10 Juin 2026, 00:13
Arnold Win32 (02-01-2009)
 [ 5 message(s) ]
 Sujet du message : Arnold Win32 (02-01-2009)
Message Publié : 02 Fév 2009, 22:14
Message(s) : 5136
jan 2009
- arnold started up with something that looked like a cpc6128 but was cassette based.
now fixed. arnold starts with a real cpc6128 configuration.
- started to implement a new "load file into ram" option. Not finished yet but I was going to use
this to run some tests with arnold.
December 2008
- it was not possible to insert an expansion rom (now fixed). clicking on load button would not do anything.
- lots of dissassembly errors fixed. Some instructions were wrong, some were not formatted correctly. Some
were inconsistent.
- If Arnold failed to auto-start a disc it would not tell you.
- If Arnold failed to auto-start a disc it would leave autotype on and would print garbage. Cpc would hang.
- If Arnold failed to auto-start a disc it would leave autotype on, reset did not stop it. Cpc would be hung after reset.
- Failed to autostart discs where directory had graphics and the only file to run was hidden.
- Can now load 256k and 512k snapshots.
- Much more tolerant to bad snapshots (bad length).
- Can now autostart disc/tape on cpc+.
- compressed memory blocks in snapshot v3 are now supported (snapshots written by winape should now load)
- disc image filename blocks in snapshot v3 specification are now supported (snapshots written by winape should now load)
- scroll lock led no longer reflects drive led. it was not useful because it only reflected the state of the internal drive anyway.
November 2008
Fixes:
- Ukonx tracker now loads.
- Last Ninja 2 Remix (protected disc image) can now be inserted without Arnold crashing
- Natural Bug Killer demo now runs
- Inserting some disc images would cause Arnold to crash.
- Fixed bug with CPC+ snapshot loading/saving. Some snapshots identify themselves for CPC
old generation, but if a CPC+ special block is found it is assumed CPC+ is used.
- Fixed a bug in the fdc emulation meaning Natural Bug Killers would hang after intro part.
url : http://www.kjthacker.f2s.com/arnold-02-01-2009.zip
Capitaine
 Sujet du message : Re: Arnold Win32 (02-01-2009)
Message Publié : 12 Fév 2009, 16:20
Message(s) : 5
OH putainn merci ! :winner:
Ca fait des années que j'attendais une mise à jour.
Le site http://arnold.emuunlim.com avait été piraté
mais ce http://www.kjthacker.f2s.com c'est le nouveau site officiel ?
J'aimerais bien aussi une mise à jour sur Caprice32... :twisted:
Bon j'ai parlé trop, vite le lien est mort :(
Message Publié : 12 Fév 2009, 20:59
Message(s) : 5136
je te l'ai mis par la : https://cpcrulez.fr/emulateurs_download ... old.htm#DL
Capitaine
Message Publié : 13 Fév 2009, 13:04
Message(s) : 5
Merci ! :)
Par contre je viens de voir encore une autre version annoncée sur cpczone.net
http://www.kjthacker.f2s.com/arnold-03-02-2009.zip
Message Publié : 13 Fév 2009, 20:48
Message(s) : 5136
Nikel, j'ouvre un nouveau topic alors!
 [ 5 message(s) ]
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 28 invité(s)
