Nous sommes actuellement le 14 Jan 2026, 18:55
[EMU] ACE-DL : ACE Linux/MacOS/Win port
 [ 25 message(s) ]  Aller vers la page Précédent  1, 2
 Sujet du message : Re: [EMU] ACE-DL : ACE Linux/MacOS/Win port
Message Publié : 15 Déc 2024, 15:18
Message(s) : 3615
Last official release O.D.I.L.E. - 2024/12/14
- added new traductions
- added FullScreen mode for Linux/Windows users (F11 key)
- upgrade width/height limit to 512 in Graphics Explorer
- added Amsdos header option for Memory import in configuration saves
- now you can resize Graphics Explorer window + size saved in configuration
- display an error message when a file is not supported (instead of simply discarding it)
- bugfix step over in trace with HALT, LDIR, CPIR and other 'looped' instructions
- bugfix number of selected Upper Rom, displayed in Gate Array window
- bugfix number of selected bytes after a successful search
- bugfix recovery of explorers coordinates after close/reopening
src/url: http://www.roudoudou.com/ACE-DL/
Message Publié : 28 Déc 2024, 09:12
Message(s) : 3615
Last official release Noël - 2024/12/24
- spanish translations for the GUI (see flags with F12)
- ability to use (L)abels to jump in memory from Graphics Explorer
- +/- from numeric keypad change emulation output volume
Message Publié : 24 Jan 2025, 13:48
Message(s) : 3615
Last official release JoooOOOOooonnnvier! - 2025/01/22
- upgraded iMPdraw rom pack to sept 2024
- new options for EDSK autosave and versioning
- ability to save Tiles/Sprites in graphic explorer
- ability to load RASM symbols chunk in Cartridge (get new Rasm!)
- ability to toggle all execution breakPoints from Trace with key 'T'
- execution breakPoints in watcher mode are now green in Trace
src/url: https://roudoudou.com/ACE-DL/
Message Publié : 12 Fév 2025, 11:12
Message(s) : 3615
Last official release Guy Leven - 2025/02/11
- Minor release solving the problem of moving windows when using lateral taskBar or upper taskBar
src/url: https://roudoudou.com/ACE-DL/ ;linked:
Message Publié : 24 Fév 2025, 17:36
Message(s) : 3615
Last official release SDL3 - 2025/02/24
- Now using SDL version 3 which include strong internal changes
- New joystick management engine (should fix xbox joystick issue, and more)
- Analog joystick support for Amstrad Plus/GX-4000 + bugs optional emulation
- Improve responsiveness of keyboard inputs in GUI
- Bugfix Virtual keyboard (wasn't exporting keys)
- Highlight modifications in Memory Explorer
- FullScreen now use hardware blit rescale
Message Publié : 30 Mars 2025, 16:38
Message(s) : 3615
Many ergonomics fixes, graphic glitches. Cathodic filter minor modification
New additionnal memory selection capabilities (see documentation below)
Last official release Mars - 2025/03/28
- Trim end of filenames to remove spaces (mostly a ManageDsk problem with existing names)
- Do NOT play Relay Click sample when using CRTC-3 (Plus/GX) model
- Fix window glitch when redefining joystick
- Fix double window blit with Graphic Explorer
- Minor Cathodic filter light propagation enhancement
- Keep line count display in HUD during paused emulation (Trace)
- Ability to click and drag for memory selection in Memory Explorer
- Ability to set end of selection with SHIFT-G (goto) in Memory Explorer
Message Publié : 13 Mai 2025, 19:39
Message(s) : 3615
Last official release MayLeven - 2025/05/11
- Update SDL3 to 3.2.12 version (more joysticks supported)
- Enforce window position inside available screens
- Cursor navigation in Label search window
- Raise window in case asking for it but already opened
- Stack values in Trace may be clicked to jump to these values
- Bugfix fastSearch in file selector with lower case + reloop on a key
url/src: https://roudoudou.com/ACE-DL/
Message Publié : 14 Oct 2025, 20:41
Message(s) : 3615
New build for Raspberry Pi - 2025/10/13
no update for the other OS, we are still working on expansion cards...
- Update SDL3 to 3.2.16 version (X11 fullscreen fixes, MacOS Catalina mouse fixes)
- Allow to change memory source in Memory Explorer without going to debug
- Ability to save media (F4 key) from floppy file management
- Ability to change audio driver from configuration menu + saved in configuration
- Fix extended cartridge slot count + NBBK endian read
- Fix SDL3 audio driver selection from command line
- Fix Mono/Stereo switch in Machine configuration (no need to restart emulator to be effective)
Message Publié : 04 Nov 2025, 10:09
Message(s) : 3615
BND-5 RELEASE (2025/11/03)
- Raspberry Pi version \o/
- Update SDL3 to 3.2.24
- bugfix hardware configuration option submenu
- bugfix joystick configuration (random consideration)
- bugfix interrupt order and ack (thanks to NoRecess)
- bugfix on CRTC-2
- little adjustment in free/adaptive/g-Sync management
- new plugin for MasterCity soundcard (ym2412) thanks to Syx
- Samples and OPL emulation for Play2CPC thanks to Syx
- plugin audio emulation rewritten to fit original ACE management
- cosmetics in AY module
- added interrupt pending in Gate Array visualization
- new command line to disable all windows but the emulator
- do not bother endlessly with DSK to save when user sayed No
- ability to load floppy image in A: or B: by prefixing their names
- added red border with disabled sprite or green border with sprite enable
Message Publié : 31 Déc 2025, 16:36
Message(s) : 3615
2025 Before New Year's Eve (30/12/2025)
- ability to execute data after load in memory explorer, with or without AMDSOS header (drag inside center box)
- bugfix Memory explorer emulator mapping in Plus mode... (nobody using it? ^_^)
- bugfix regression in keyboard selection for Mac
- added new translations in configuration menu
- added DSK watcher on all drives (see other misc options)
- added CPC+ chunk decoding when loading ACE snapshot
- added CRTC address next to memory address in graphic explorer
- added hardware sprite highlight (in most standard multiplexing cases)
url/src: https://roudoudou.com/ACE-DL/ ;linked:
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 41 invité(s)
