You need a formatted disk from windows. Once covered the "high density" tab on the floppy, you have to format it in FAT 720Kb using the windows command line "FORMAT A: /T:80 /N:9". Start CPCDiskXP, press 'DSK Editor' button. 'New', select IBM format (last in the list). Now Add the files you want to write Press 'Write USB Floppy' button to write the Dsk. Test/Load on your real CPC... Mais 156k par face tu veux faire quoi avec ca..meme un dsk cest trop grand..jesperre qu'il vont sortir dautre version ..
Tout le monde ne se limite pas à copier des DSK de jeux existants avec son CPC.
J'ai pas dit le contraire ca va surement servir a quelqu'un..moi je resterai avec mon lecteur en ide en tout cas dici qu'il trouve un moyen d’accéder aux autre formats..
CPCDiskXP v2.5.1 Changelog (since v2.5): - DSK to Floppy - Now you can choose between two methods of writing to disk: "Low Level Driver" and "USB Floppy Drive". The option "USB Floppy Drive" will be only enabled when the format is compatible with the USB floppy writing method. - GENERAL - Now the program is able to format the disk when writing on USB floppy drives. Now that the program format and write, is no longer necessary to preformat the disk from windows. - GENERAL - Eliminated warnings that the Low Level Driver is not installed at starting the program. Now that you can write to USB floppy is not necessary to show the warning every time. - DSKEditor - New feature/button to "Add Files From Another Dsk" (or zip containing Dsk's) to easily add files that are in other Dsk without extracting them. As you can add files from one Dsk format to another Dsk format, this is also a format converter. - DSKEditor - Support for creating/editing two new IBM formats: Single Side, 42 Tracks, 168K (162K Free) and 65 Tracks, 260K (254K Free) [3.5" only, hack for AMSDOS]. Both can be written on USB floppy drives and both can be used / read in standard Amstrad CPCs. - DSKEditor - Support for creating/editing a new PCW/+3DOS format: Single Side, 42 Tracks, 189K (182K Free). It can be written on USB floppy drives and it can be used / read in standard PCW or ZX Spectrum +3. - DSKEditor - Support for creating/editing a new ROMDOS D1 format: Double Side, 80 Tracks, 720K (716K Free). It can be written on USB floppy drives. - DSKEditor - Support for creating/editing a new CPC DATA format: Single Side, 57 Tracks, 256K (254K Free) [3.5" only, hack for AMSDOS]. It can be used / read in standard Amstrad CPCs. - DSKEditor - Support for creating/editing a new CPC SYSTEM format: Single Side, 59 Tracks, 265K (254K Free) [3.5" only, hack for AMSDOS]. It can be used / read in standard Amstrad CPCs. - DSKEditor - Now when creating a new Dsk you can filter the list of formats to choose from. There are 5 filters: "All Formats", "Amstrad CPC Standard Formats", "Amstrad CPC With Modified ROM Formats", "USB Floppy Drive Compatible Formats" and "Amstrad PCW / ZX Spectrum Formats". With these filters is very clear on which platform each format works. Thank you very much to KaosOverride, I always learn new things thanks to you
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 65 invité(s)
