Pratiquement tout les emulateurs Amstrad CPC dispose d'un lancement en ligne de commande avec autotype:
CPCEmuPower_v1804.zip : a écrit :
autotype:rallentissement de la cadence de simulation d'appuie des touches pour gÚrer correctement les mot Ó taper avec deux lettres identiques example: CPCEPower_SDL.exe -c128 -0 ".DSK\Harricana - Raid International Motoneige (F) (1990) [Original] (GAPS).dsk" -a "RUN\"HARRI" example: attention, les guillements ne sont pas toujours utiles en ligne de commande CPCEPower_SDL.exe -c128 -0 ".\DSK\Fer & Flamme (F) (Face 1) (1986) [Original] (Weak Sectors).dsk" -a RUN\"F&F
Sugarbox_v0.27.zip a écrit :
- [General] : Added some command line switches : -sn xx (load xx as a Snapshot file), -drivea xx to set xx into drive A, -driveb (same for drive B) ; -fullscreen to start in full screen mode, -config xx to load xx as config file, -command xx to run xx as basic command at start
WinAPE_v2.0B02.zip a écrit :
Command Line Parameters
When starting WinAPE a disc image filename can be specified as a parameter (without the slash option). The following parameters can be specified on the command line:
Parameter Function : filename Specify the filename for the disc image to be used in Drive A: /A Automatically run the program in Drive A:. To specify the name of the program to run use /A:filename. To start a disc using a CP/M boot sector use /A:|CPM /T:filename Automatically start typing from the given Auto-type file. /SN:filename Specify a Snapshot file to be loaded and automatically started. /SYM:filename Load a file containing assembler/debugger symbols. /SHUTDOWN Shut down Windows when WinAPE is closed. Use /SHUTDOWN:FORCE to force shutdown if required.
For example, to start WinAPE using the disc image frogger.dsk contained within a Zip file frogger.zip and run the program named frogger use: WinAPE frogger.zip\:frogger.dsk /a:frogger
Je vois bien ce que tu veux dire mais dans le cas de la recalbox (distribution pour raspberry pi), on se contente de déposer les ROMs sur un partage réseau (Samba) et on lance depuis une interface graphique qui affiche la liste des jeux déposés.
Du coup, je ne vois pas du tout comment l'émulateur détermine le fichier d'autoboot ? d'autant que si je comprends bien, cela ne se trouve pas dans le fichier .DSK mais c'est une option de l'émulateur.
c'est la quelle d'interface qui est utiliser sur ta distribution de recalbox , RetroArch ? tu sais quel emulateur est lancé ? il y a peut-etre un fichier conf a ajouter a côté de chaque .dsk ...
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 58 invité(s)
