Nous sommes actuellement le 17 Juil 2026, 06:46
[DIY] Expansion Cards by Revaldinho
 [ 9 message(s) ]
 Sujet du message : [DIY] Expansion Cards by Revaldinho
Message Publié : 07 Oct 2020, 14:53
Message(s) : 3686
Amstrad CPC RAM Expansion
The main event in this GitHub project is a 1MByte RAM Expansion card for the Amstrad CPC computers from the 1980s.
CPC RAM Expansion Cards: 'Old School' CPC6128 512KB and 1MB RAM Expansion Cards
  • Two cards specifically for the 6128 and 6128 Plus and created entirely with standard 74 series ICs
    • 512KByte version
    • 1MB Version
CPC RAM Expansion Cards: Universal Amstrad CPC RAM Card
  • Two Universal RAM cards, compatible with all Amstrad CPC computers providing full 6128 compatibility on a 464
    • 512KByte version
    • 1MB Version
CPC 4 ROM Expansion Card : CPC Fourrom Card
  • This project is a CPLD-based ROM expansion board. Although only 2 sockets are provided each can be filled with a 'double size' EEPROM to provide the equivalent of 4 classic 16KByte Amstrad ROMs.
  • The board will co-exist with other ROM cards and uses DIP switches to enable or disable ROMs individually and to select how the ROMs on the card will be numbered to avoid clashes with other cards.
CPC 6 ROM Expansion Card : CPC Sixrom Card
  • This project is a CPLD-based ROM expansion board. Although only 3 sockets are provided each can be filled with a 'double size' EEPROM to provide the equivalent of 6 classic 16KByte Amstrad ROMs.
CPC Expansion backplane
  • The two 4 slot cards are identical apart from the pass through connector being replaced by an reproduction of the Amstrad CPC edge connector. This is useful if you need to use any legacy edge connector peripherals as well as the newer MX4 slot types, and particularly for CPC464 users who may have a DDI-1 disk drive controller or DDI-3 USB interface.
  • The expansion slots on all cards are fully compatible with modern Amstrad CPC Peripherals such as Duke's M4 Card, the X-MEM RAM/ROM board and of course the RAM, ROM and Z80Tube expansions all described in the GitHub repositories here.
All of the above projects have been built and tested.
Eagle PCB files and zipped archives suitable for getting boards made are included in the Eagle Releases subdirectory.
For more information on all projects see the Project Wiki Pages
All programs and data files in this project are made available under the terms of the GNU General Public License v3.
url: https://github.com/revaldinho/cpc_ram_e ... sion-Cards
url: https://github.com/revaldinho/cpc_ram_e ... C-RAM-Card
url: https://github.com/revaldinho/cpc_ram_e ... urrom-Card
url: https://github.com/revaldinho/cpc_ram_e ... ixrom-Card
url: https://github.com/revaldinho/cpc_ram_e ... backplane/
src: http://www.github.com/revaldinho/cpc_ram_expansion/wiki
 Sujet du message : Re: [NEW] Expansion Cards by Revaldinho
Message Publié : 08 Oct 2020, 07:48
Merci Revaldinho !
Grâce à tant de générosité, on peut acheter sur eBay des extensions RAM ou ROM à 40/50€, des MotherBoard à 40/50€, des PCB nues à 15/20€ ... Tout ce dont on était préservé sur notre machine depuis la MegaFlash... Trop généreux !
Vive les projets libres*. Vive le retour du business retro sur CPC !!! :-)
* Ha oui, "on" est pas responsable de l'usage ni de penser aux conséquences...
norecess464
Message Publié : 08 Oct 2020, 14:55
:downnn:
iXien
Message Publié : 08 Oct 2020, 20:25
Message(s) : 155
Tout pareil :downnn:
Gerald
Message Publié : 09 Oct 2020, 07:40
TotO a écrit :
Merci Revaldinho !
Et tu fait quoi de tout ceux qui se la fabrique eux même et que tu ne vois pas ? :sigh:
Message Publié : 09 Oct 2020, 08:07
Message(s) : 519
statistiquement c'est anecdotique, sinon vous n'auriez pas vendu des centaines de cartes, faciles à réaliser pour certaines
bon après si on les retrouve avec une marge sur ebay c'est que ça ne produit pas assez en amont
si y avait eu plus de dispo sur le dandanator, zaxxon n'aurait pas fait son coup de vendre le mini au prix du gold toutes options
Message Publié : 09 Oct 2020, 08:43
En ligne
Message(s) : 5140
Il y aura toujours la loi de l'offre et de la demande , toujours des crevards pour profité du système ... .(
A notre niveau ont ne peu qu'aiguiller les gens vers des vendeurs honnête.
Gerald
Message Publié : 09 Oct 2020, 16:37
C'est toujours un compromis entre le temps que ça prend et le prix que ça coute. Le côté open-source aura toujours un avantage : si personne ne le propose à la vente, tu peux le faire toi même (sans parler du partage de connaissance).
C'est l'effet j'ai pas le temps de produite/gérer les commandes, je vous laisse vous démerder du HW open source :sweatingbullets:
Aprés, le marché fait le reste :eng:
Message Publié : 12 Oct 2020, 08:09
Ma préoccupation ici est plutôt : Et l'on fait quoi de ceux qui achètent pour 120/150€ de matos parce qu'ils ne savent pas qu'ils peuvent avoir l'équivalent pour 40/50€ assemblé ou pour 30/40€ en kit. Surtout que ces personnes entrent à un moment où un autre dans la "communauté" et se rendent comptent qu'ils se sont fait "violer" au premier contact avec le monde retro CPC.
Je vais me répéter, mais si j'ai commencé en 2012 à réaliser mes propres extensions, c'est exactement pour m'éviter cela et finalement essayer de le limiter pour d'autres. Après je ne suis pas dupe, on ne peut pas sauver tout le monde... Mais cela n'empêche pas d'avoir une réflection autour des moyens permettant de limiter un problème plutôt que l'amplifier. Aussi, la fatalité c'est pas une solution en soi.
EDIT: Acheter des extensions de plus en plus cher c'est accepter d'acheter la machine pour les brancher de plus en plus cher aussi (on le voit sur Amiga, Mega Drive, etc). C'est une dérive qui nous concerne donc tous indirectement et l'Open Source "tout cuit" n'est pas vraiment une solution à cela.
 [ 9 message(s) ]
