Nous sommes actuellement le 12 Mai 2026, 06:02
Symbiface 3
 [ 14 message(s) ]
 Sujet du message : Symbiface 3
Message Publié : 22 Jan 2009, 00:54
Message(s) : 5131
The Symbiface3 which offers:
- USB with built-in two-port root hub. capable of 1,5 and 12MBits/s transfer rate
* Internal handeled protocol stack including enumeration and device driver
probing
* complete HAL to simplify accessing the different components connected
* software support to develop and dynamically upload additional class drivers
- Networking
* Standard Ethernet-interface with full duplex 10Mbits/s
* Internal handeled TCP-Stack extendable by dynamically loadable modules
* simple file-like interfaceing on the cpc/msx side
(open/close/read/write/resolveDNS)
- Sound
* MP3-Decoding and Wave (PCM / IMA-ADPCM) playback with a large 32kbytes of
playback buffer
* user loadable DSP-Software like equalizers and so on
* Passthrough and mixing of the CPC's sound output
* readback of the audio-output for capturing purposes
- Built in non volatile Memory
* 4Mbytes of flash memory accessable like any other drive provided by the
SF3 and thus supported by SymbOS
- Core
* Here too, we have loadable module support to extend the use of the SF3's
processor
The SymStation extends this by:
- FPGA
* Altera Cyclone3 EP3C10E144 ( which is big enough to have even two CPCs
inside it ;) )
- 16 or 32MBytes of SDRAM
- A framework will be provided to support you in writing own cores.
- Stand-alone housing made from eloxated aluminium. Handcrafted, of course ;)
- Grafical core-selection system to choose "where you want to go today"
- Hopefully the one or the other finished core for you to play with.
Until now the integration into SymbOS covers networking (working so far) and
Mass-Storage
wich needs further testing up to now.
NiNxPe
 Sujet du message : Re: Symbiface 3
Message Publié : 22 Jan 2009, 01:51
Message(s) : 98
Bonjour tout le monde ,
Sait-on quand la SYMBIFACE 3 sera disponible et comment s'en procurer une ?
Sur le site de Prodatron aucune newz.
Longshot
Message Publié : 22 Jan 2009, 10:40
Message(s) : 270
Je suis pas sûr de bien comprendre l'utilité, mais ce truc est sensé se connecter au cpc avec en interne de l'ethernet, des usb, du son, décodage mp3, trifouillage du son cpc, capture du son, des mégas octets de ram, émulateurs hardware de 2 cpc, ...?
C'est pas le cpc qui est l'interface de symbiface ? :sweatingbullets:
Message Publié : 22 Jan 2009, 13:46
Message(s) : 5131
SymbiFace3 Wiki by DrZed : http://sf3doc.dr-zed.de/index.php/Main_Page
NiNxPe
Message Publié : 22 Jan 2009, 19:26
Message(s) : 98
Apres quelques recherches sur le net la SYMBIFACE 3 porte tres mal son nom.
En effet, d'apres ce que j'en ai compris par Prodatron c'est une extension de la SYMBIFACE 2 et donc inutilisable SANS cette derniere.
Je m'imaginais autre chose de ce qu'était la SYMBIFACE et apres reflexion et surtout pour ce que j'croyais en faire mieux vaut me retourner pour une solution de type SDiskEmul.
Et comme Longshot je m'interroge du coups sur l'utilité, ceci dit c'est toujours amusant de voir qu'en 2009 des passionnés arrivent a nous sortir encore des extensions pour CPC et rien que pour ça et parceque je ne suis pas capable d'en faire autant je les félicitent.
Longshot
Message Publié : 23 Jan 2009, 09:27
Message(s) : 270
Toutes les cartes visant à doter le cpc de nouvelles capacités fondamentales (nouveaux modes graphiques , usb, ethernet, mega octets de ram, ...) me parait surtout faire le bonheur d'électroniciens, mais ne me semble pas très utile à la communauté des cpciens.
L'intérêt de travailler sur un vieux micro pour la majorité des sceneurs, c'est justement d'utiliser ses capacités d'origine, car c'est un référent commun (ce que justement le monde du pc a détruit). Je conçois des cartes électroniques comme la cpc booster ou la ramcard qui permettent la communication ou la gestion des roms telle que prévue nativement sur cpc à des fins de facilitation de développement des capacités d'origine.
Mais vraiment pas ces cartes dont l'objectif est douteux, car il vise à tenter d'imiter ce que font très bien et bien mieux les pc modernes (super graphismes, internet, lecture mp3, ...)
BDCIron
Message Publié : 23 Jan 2009, 12:30
Entièrement d'accord avec Shot !!! Pour moi les seules choses tolérables sont les supports. Par exemple les truc avec carte SD qui "emulent" le lecteur de D7 ce montreront utiles par la suite (surtout vu que les 3.5" c'est fini). Pour le reste, rajouter des couleurs; des résolutions etc... Autant passer sur PC directement.
fkey
Message Publié : 25 Mai 2009, 16:39
Message(s) : 95
Bof pas d'accord là ...
Amstrad a prévu une sortie EXT, autant s'en servir.
Il me semble que vous confondez la symbiface2 avec symbos, l'un étant une carte permettant de brancher un disque dur sur cpc (+souris +horloge +ram +rom ), l'autre étant un os imitant MsWindows.
Avec cette carte et une rom adéquate (qui n'existe pas encore à ma connaissance) il me parait intéressant de pouvoir utiliser ses capacités pour :
- La programmation
- Le dessin
- La musique
Surtout que l'accès en lecture est rapide et un disque dur est quelque-chose de très confortable pour avoir tous ses petits à portée de main.
Bref je ne vois pas trop en quoi on pourrait la distinguer des cartes du style cpcbooster.
Et puis il ne faut pas tout confondre à mon avis ce sont les PCs qui se sont inspirés de notre génialissme cpc pas l'inverse :D
BDCIron
Message Publié : 25 Mai 2009, 18:01
C'est la ou on fait la difference entre un demomaker et un... je sais pas quoi... Le demomaker exploite un systeme figé et essaye d'en sortir un maximum de chose sans changer quoi que ce soit a la machine... Si tu veux faire de la musique avec une meilleur carte; ajouter de la ram etc, achetes un PC...
Une souris sur cpc ca ne sert a rien et n'est pas adapté à la machine dans aucun cas; une horloge j'en ai une au mur; sur mon telephone; ma montre etc, pas besoin d'en avoir une sur CPC: aucun interet. Plus de RAM ? Plus de ROM ? pourquoi faire ? t'as déjà utilisé toutes les ROMs d'un CPC ? Et la RAM, t'as déjà fait quelque chose qui l'utilise entièrement ??? Non ??? Ah bon, je croyais vu que t'en veux plus...
La distinguer d'un cpcbooster est facile: la cpcbooster n'est qu'un pauvre interface de transfert, elle ne change pas le fonctionnement de la machine et en plus, on s'en passe super bien (la preuve la mienne n'a servit que 2 fois)...
Message Publié : 25 Mai 2009, 19:04
C'est moi où vous dites la meme chose ??
En bref, vous que: Tant que ça sert au developpement (musique, gfx, code ....) c'est cool; sinon ça sert à rien....
Si c'est bien ce que vous pensez tous les deux alors on est trois :mdr:
BDCIron
Message Publié : 25 Mai 2009, 19:35
C'est tout a fait cela :)
fkey
Message Publié : 25 Mai 2009, 22:35
Message(s) : 95
Tout ça me dépasse un peu je dois dire ...
Moi je trouve ça super sympa comme materiel.
Une chose est cependant limpide, je suis décu de voir que l'on ne peut pas émettre un avis contraire au tien sans essuyer de cinglants sarcasmes.
Supersly
Message Publié : 26 Mai 2009, 05:20
Message(s) : 405
Il est certain que je ne me servirai jamais de ce genre d'interface, mais se poiler en l'inventant n'est pas plus con que de faire des démos sur un 8 bits...
Après, discuter de l'utilité de ces interfaces ou de celles des démos... prrrt !
Les Sucres en Morceaux
Message Publié : 23 Avr 2010, 12:50
Message(s) : 5131
comme kawickboy me l'a fait remarquer le mini wiki n'est plus dispo le projet est peut-être maintenant abandonné ?
dernier msg sur la SF3 : http://dr-zed.de/?p=100
 [ 14 message(s) ]
