Nous sommes actuellement le 12 Août 2026, 07:44
HxC Floppy Emulator
Publier un nouveau sujet Répondre au sujet  Page 45 sur 50
 [ 742 message(s) ]  Aller vers la page Précédent  1 ... 42, 43, 44, 45, 46, 47, 48 ... 50  Suivant
Jeff_HxC2001
Message Publié : 10 Mars 2019, 21:43
Message(s) : 269
10 March 2019 : Firmware STM32 USB HxCFloppyEmulator v3.1.39.1a ( -> In the "WIP_Firmware" Folder and https://hxc2001.com/custom_fw/)
- Indexed mode files naming convention enhanced :
-> DSKAXXXX become a prefix : You can now add something after the prefix. e.g : DSKA0000_MyDiskName.IMG, DSKA0001_SaveDisk.HFE...
-> The prefix can be changed on the customization page if you don't like it : https://hxc2001.com/custom_fw/
- AUTOBOOT and config files names are now not case sensitive.
- And some more fixes (rotary settings...).
Customization page : https://hxc2001.com/custom_fw/
https://hxc2001.com/download/floppy_drive_emulator/HXCFEUSB_HFE_beta_firmware.zip
https://hxc2001.com/download/floppy_drive_emulator/USB_HFE_hxc_floppy_emulator_firmware_release_notes.txt
Jeff_HxC2001
Message Publié : 17 Mars 2019, 22:17
Message(s) : 269
17 March 2019 : Firmware STM32 USB HxCFloppyEmulator v3.1.41.1a ( -> In the "WIP_Firmware" Folder and https://hxc2001.com/custom_fw/)
- Blackberry trackball support.
- Track position display changed to when the screen line size is less than 16 characters.
Jeff_HxC2001
Message Publié : 21 Mars 2019, 13:57
Message(s) : 269
21 March 2019 : Firmware STM32 USB HxCFloppyEmulator v3.1.44.2a ( -> In the "WIP_Firmware" Folder and https://hxc2001.com/custom_fw/)
- Some fixes in the user defined image feature.
- Custom firmware option : Display the current track number on the 7 segment screen.
- Custom firmware option : Debug output on the serial port (115200 8N1).
- Custom firmware option : Read pipeline buffer size.
- New system family support : Kawai.
Jeff_HxC2001
Message Publié : 24 Mars 2019, 14:49
Message(s) : 269
24 March 2019 : Firmware STM32 USB HxCFloppyEmulator v3.1.45.1a ( -> In the "WIP_Firmware" Folder and https://hxc2001.com/custom_fw/)
- Custom firmware option : Blackberry trackball -> Single and double step support.
- Custom firmware option : Extra up/down buttons or navigation switchs on the rotary connectors.
Jeff_HxC2001
Message Publié : 26 Mars 2019, 10:58
Message(s) : 269
26 March 2019 : Firmware STM32 USB HxCFloppyEmulator v3.1.45.2a ( -> In the "WIP_Firmware" Folder and https://hxc2001.com/custom_fw/)
- New Custom firmware option : File format -> support now images with tracks in opposite order on the side 0.
(Side 0 tracks file opposite order option)
Jeff_HxC2001
Message Publié : 26 Mars 2019, 13:23
Message(s) : 269
Bon, pour info cette release était un piège pour une personne bien précise. La feature annoncée est complètement bidon et n'a aucun sens : aucune image n'a de piste inversé en side 0. Je n'ai rien changé au code, juste fait une fake release note.
Le piège a très bien fonctionné : la feature "débile" a été copiée, codée et commitée par l'auteur du projet concurrent en moins de 50 minutes. Je pensais qu'il allait prendre quelques jours mais là c'est un record ! :mdr:
https://hxc2001.com/vrac/Screenshot%20a ... -20-30.png
https://github.com/keirf/FlashFloppy/co ... 800450165e
https://github.com/keirf/FlashFloppy/wi ... e/_history
Non seulement ça plagie mais en plus ça pompe des trucs débiles sans réfléchir et sans besoin derrière ...
Message Publié : 27 Mars 2019, 14:28
Message(s) : 519
Au moins on sait qu'il code lui même les fonctionnalités du gotek :D
Jeff_HxC2001
Message Publié : 27 Mars 2019, 16:47
Message(s) : 269
:mdr:
Oui encore heureux... Mais il se sert allégrement des outils HxC et sources disponibles... Il fait beaucoup de réécriture à partir de sources de tierces personnes (moi ou autre...).
Il a également carrément forké le file selector HxC pour supprimer la demande de contribution que j'avais mis quand le soft détectait son firmware...
Message Publié : 27 Mars 2019, 17:34
Message(s) : 519
on est d'accord que sa démarche n'est pas honnête
Jeff_HxC2001
Message Publié : 28 Mars 2019, 00:20
Message(s) : 269
Oui... Mais voilà, il a le beau rôle lui, celui du "chevalier blanc". :D
C'est d'ailleurs pour cela qu'il se permet ce genre de connerie...
Illustration :
https://www.youtube.com/watch?v=DQkGey_-W8c
On m'appelle le Chevalier Blanc...
Je vais et vole au secours d'innocents...
Qu'en la campagne résonne la poudre...
Je vais et vole plus vif que la foudre...
La la la...
La la la...
:mdr:
Message Publié : 28 Mars 2019, 09:13
Message(s) : 516
Lanvin renie ce rôle pourtant majeur dans sa carrière.
Sinon comme il est Anglais, tu devrais passer expliquer gentiment la situation sur cpcwiki.
Message Publié : 28 Mars 2019, 10:01
Ce que tu as fait était donc propablement nécessaire et pour cause :
Certaines personnes ont remarqué qu'avant l'arrivé du projet de Keirf, plus rien ne bougait sur "HxC" et que le format DSK tant attendu depuis 2 ans n'était pas du tout ta priorité. Son arrivé a donc été une bénédiction pour de nombreux utilisateurs CPC, quoi que tu puisses en dire. Surtout que ses releases de nouvelles fonctionnalités se faisaient avant les tiennes (CVS a l'appuye). Comment parler de coincidence ou de copie ainsi ?
Je ne suis pas le seul à avoir remarqué que l'arrivé de ce projet parallèle à créé un regain de développement de ton coté. Tu expliquais cela par une fuite dans ton équipe de test. Mais en même temps si un type recode tes fonctionnalités pour les sortir avant, dificile de ne pas te reprocher de t'être reposé sur tes lauriers, jusqu'à l'arrivée de cette concurence apparu à un moment ou tu avais décidé d'augmenter de 20% le prix de tes licences (10€ -> 12€ par Gotek acheté 16/18$ pièce ports compris) sans visibilité sur les fonctionnalités futures d'un produit qui n'évoluait plus... Ceci ayant peut-être motivé cela.
Après, tu es certainement le mieux placé pour dire ce qu'il en est réellement, juste que ce que je relate est l'impression vu de l'extérieur par certains utilisateurs assidus.
Hyroniquement, tu le caricature comme le chevalier blanc mais où en serions nous aujourd'hui ? Tu lui a donné accès a ton source, comment veux-tu lui reprocher de l'utiliser ?
Jeff_HxC2001
Message Publié : 28 Mars 2019, 11:46
Message(s) : 269
Mais?... Il me semble vous avoir déjà repondu il y a un bon paquet de mois à ce sujet ?
<<qu'avant l'arrivé du projet de Keirf, plus rien ne bougait sur "HxC" ...>>
Je vous laisse le soin de visiter les discutions et les tests des firmwares HxC en version alpha sur le forum eab abime avant l'arrivée du sauveur :
http://eab.abime.net/showthread.php?t=78079&page=22
puis :
http://torlus.com/floppy/forum/viewtopi ... =33&t=3147
C'est sur que "plus rien ne bougeait" :D
Sinon ma réponse d'il y a 9 mois est sur ce forum ici même concernant le reste (les dsk & co...) :
viewtopic.php?p=53979#p53979
Puis ça aussi comme exemple:
viewtopic.php?p=53988#p53988
Sinon l'augmentation du tarif c'est juste suite a mon changement de statuts fin 2016 début 2017 (AE vers Portage salarial).
C'est juste la TVA... Personnellement je ne touche rien de plus... Mais bon 2 Euros ça ne devrait pas trucider le "casual gotekeur" nan ?
Pour les revendeurs déclarés et travaillant légalement c'est 0 Euros de TVA, en plus d'une grosse ristourne dispo depuis le début donc bon... (7 Euros par paquet de 30).
Mais bon arrêtons de se raconter des histoires, je pense que la motivation première pour l'ensemble c'est de payer 0 Euro, il ne faut pas se leurrer.
Alors oui effectivement je suis d'accord avec vous, d'après vos dires il a été tristement nécessaire de le prendre en "flag" avec ça :
viewtopic.php?p=54534#p54534
parce que les utilisateurs "assidus" ne sont pas forcement bien avisés.
( Mais c'était très très drôle à faire et la supercherie ne m'a pris que 5 minutes à mettre en place, idée incluse :D )
Message Publié : 28 Mars 2019, 12:20
Evidemment, se ne sont pas des accusations que je porte, mais un petit résumé d'un constat qui a pu préter à confusion.
Contant que tu te sois bien amusé. Juste, tu aurais pu attendre le 1er Avril !
Jeff_HxC2001
Message Publié : 28 Mars 2019, 12:22
Message(s) : 269
Ce n'est pas forcement nécessaire : Je l'ai déjà fait sur eab.abime et il a "acquitté" :
http://eab.abime.net/showpost.php?p=131 ... count=1181
Sa réponse : "That's business :D"
Au moins c'est clair pour ceux qui en doutait. :D
En fait il ne s'en cache pas. C'était même un argument de vente dans les premières versions de son readme de son github :
"Compatible avec l'environnement HxC".
