Bonjour, Une nouvelle version d'Orgams est sortie et elle corrige notamment le bug d'impression, le bug de la pile lors du debug/desassemblage et la compatibilité avec le HXC manager de NoRecess. Un grand merci au développeur.
La version du 18-fev-2018 (orgams-180218-roms-ch.hfe) : Elle apporte son lot de corrections et améliorations
Release notedraft. Demomaker's delight.
Bug fix: --- Editor ------- * CONTROL-* and CTRL-ENTER now pick the right label * TAB after CONTROL-* * Block markers display * Dump to Printer correctly output a new line * Cursor not lost anymore after reset while editing a field --- Assembler ---- * Opcodes no more seen as labels when entered without space * Allow assembling in 00-3F (!!! minus 30-32) * Correctly report label overflow (instead of Syntax Error with wrong line number) --- Trace --- * CPD/CPIR/CPDR now correctly emulated
New features: --- Editor ------- * All keys enabled while editing fields * Use lowercase for opcodes * Lines number shaded --- Assembler ---- * MACRO directive * Max number of labels is now 1536 (instead of 768) --- Monitor --- * Command history (cursor up/down) * Skip 00 filled areas in memory dump (m)
Regressions (to be fixed before release): --- Editor ------- * !! Big files around 64k may not be loadable anymore !! * even slower parsing / import
--- Editor ------- * CONTROL-* and CTRL-ENTER now pick the right label * TAB after CONTROL-* * Block markers display * Dump to Printer correctly output a new line * Cursor not lost anymore after reset while editing a field * Opcodes no more seen as labels when entered without space * Conversely, do not expand valid labels * lda,1 -> ld a,1 * inca -> inca (stay as label)
--- Assembler ---- * Allow assembling in 00-3F (!!! minus 30-32) * Correctly report label overflow (instead of Syntax Error with wrong line number)
#### New features ####
--- Monitor --- * Command history (cursor up/down) * Skip 00 filled areas in memory dump (m) * Finer navigation control * Dnn: disassemble at nn (change >) * $nn: set PC to nn and go to trace (change $) * Tnn: set PC to nn and go to trace at nn (change both)
#### Regressions (to be fixed before release) ####
--- Assembler ---- * MACRO directive * Max number of labels is now 1536 (instead of 768) * Raise source limit to ~111k
#### Bug fix ####
--- Editor ------- * CONTROL-* and CTRL-ENTER now pick the right label * TAB after CONTROL-* * Block markers display * Dump to Printer correctly output a new line * Cursor not lost anymore after reset while editing a field * Opcodes no more seen as labels when entered without space * Conversely, do not expand valid labels * inca -> inca (stay as label) * but: lda,1 -> ld a,1
#### New features #### --- Assembler ---- * New directive: SKIP n (aka DS n) * DEFB, DB aliases for BYTE * DEFW, DW aliases for WORD * DEFS, DS n,x aliases for FILL n,x #### Bug fix ####
--- Assembler ---- * MACRO directive * New directive: SKIP n (aka DS n) * DEFB, DB aliases for BYTE * DEFW, DW aliases for WORD * DEFS, DS n,x aliases for FILL n,x * Max number of labels is now 1536 (instead of 768)
--- Editor ------- * Raise source limit to ~111k * All keys enabled while editing fields * Use lowercase for opcodes * Lines number shaded * Checksums in .o files
#### Bug fix ####
--- Editor ------- * Opcodes no more seen as labels when entered without space * Conversely, do not expand valid labels * inca -> inca (stay as label) * but: lda,1 -> ld a,1 * CONTROL-* and CTRL-ENTER now pick the right label * TAB after CONTROL-* continues searching same label * Dump to Printer correctly output a new line * Block markers display * Cursor not lost anymore after reset while editing a field
Download last working FF orgams-211219-FF-beta9.dsk
Status: Very stable. There still might be some assert triggered from time to time (Orgams auto-detection of something gone wrong, leading to a breakpoint). That's extremely rare though: I cannot even reproduce! If it jumps into the debugger, please send me a screenshot.
