Nous sommes actuellement le 30 Août 2026, 20:06
[CROSSDEV] Rasm Z80 assembler by Roudoudou
 [ 27 message(s) ]  Aller vers la page Précédent  1, 2
 Sujet du message : Re: [CROSSDEV] Rasm Z80 assembler by Roudoudou
Message Publié : 28 Fév 2024, 10:36
v2.2.1/v2.2 - 2024 Valentine: fixing RLE bugfix + Autotest
- bugfix Snapshot RLE encoding
- add new math function pow2 to get fractionnal power of 2
- documentation updated
v2.1.7 - 2024 Gerieh Yasmana
Since october 2023, i'm doing a cycle of joint releases of RASM + ACE-DL Emulator so RASM versions are not major versions (until...)
- REND must trigger an error if used with parameter(s)
- enforce DEFS repeat value is not a string
v2.1.6
- minor changes in old rasm symbol file to output symbol type (L)abel (V)ariable (A)lias (I)dx
- morphOS makefile
- bugfix meta struct autofill + autotest
v2.1.5
- new directive LOCALISATION to specify a precise localisation for ACE emulator when assembling in a temporary space
v2.1.4
- minor changes in symbol export for ACE emulator
- bugfixes in HFE/DSK generation (still unfinished for HFE)
v2.1.3
- bugfixes related to wrong STRUCT usage + imbricated structs
- debug without efence, new target for fast recompilation (internal use)
v2.1.2
- new directive LABEL with options to set LOCAL/GLOBAL tag for ACE export and be more flexible
- bugfix lower ROM localisation at ACE export
v2.1.1
- minor version release on the occasion of ACE-DL emulator release
- new command line option -rasm in order to produce super symbol file for ACE-DL Emulator
- new directive EDSK to build, merge, manage, edit and assemble inside
- there is also HFE prototypes in order to manage an MFM flow (as you know, HFE is a pure track format)
- DSK support is documented on wikidot
- super snaphots Help was updated, take a look! http://rasm.wikidot.com/dev:supersnap
- windows 32bits and 64bits
- MacOS all versions executable (thanks to Sid)
url/src: https://github.com/EdouardBERGE/rasm/releases
Message Publié : 30 Mai 2024, 19:38
v2.2.4
- HFE track size fixer
- Bugfix random user with SAVE+AMSDOS when not specified, will be zero as default
v2.2.3
- HFE not protected as default
- Snapshot RAM conf default
- HFE directive subcommand bugfixes (CRC, AddGAP, ...), it's now usable ^_^
- bugfix Snapshot RLE encoding + autotest
- Online Help up to date
src/url: https://github.com/EdouardBERGE/rasm/re ... tag/v2.2.4 ;linked:
Message Publié : 24 Sep 2024, 11:43
v2.2.7
- Display how much bytes are overloading a BANK (when overload occurs)
- new directive NAMEROM (like NAMEBANK but for snapshot ROM)v2.2.7
v2.2.6 and earlier versions
- Added new option in order to ROMBANK NEXT
- Bugfix sizeof on an unknown struct may not trigger error all the time
- New math function pow2 to get fractionnal power of 2
- Bugfix "random" memory overrun with COMZ directive
- Bugfix Snapshot RLE encoding + autotest
v2.2.5
- fix random overrun of COMZ directive
Message Publié : 09 Déc 2024, 08:42
Nouvelle série d'articles d'initiation à l'assembleur sur les sprites logiciels (affichage au xor, double buffer, gestion de la transparence) avec progression d'une technique à l'autre.
src/url: https://roudoudou.com/AmstradCPC/progra ... bleur.html
Message Publié : 09 Déc 2024, 08:45
v2.2.11
- bugfix breakpoint step export
up to v2.2.10
- bugfix new variable in lower case from command line
- bugfix ACE breakpoints + evolutions
- Ability to export native breakpoints for ACE-DL emulator
- FR/EN documentation up to date
- Ability to assemble a string from command line
- Ability to export a cartridge in snapshot mode
As always, MacOS binary kindly compiled with love by Sid/iMPact
Message Publié : 10 Jan 2025, 15:32
Rasm 2.3.0 - Beacon 2025
- READ directive is now DEPRECATED! (replace them with INCLUDE)
- cartridge export may include symbols chunk for ACE-DL
- new ability to initialise structure objects
- bugfix segfault with structure self-recursive declaration
Thanks to Sid for Mac binary
url/src: https://github.com/EdouardBERGE/rasm/re ... tag/v2.3.0
Message Publié : 21 Fév 2025, 21:31
v2.3.5
- new behaviour for USED tag of aliases, variables and labels with IFUSED, IFNUSED
- new optimisations in aliases processing (benefits for all kind of calculations)
- new autotests (TDD, end-to-end, UT and exploratory tests)
v2.3.x
- new optimisations in overall processing engine leading to absurd performance peak
- added search in labels with Levenshtein distance when a symbol is not found
- better error message when there is an empty parameter
- ability to generate module names with tags
- ability to remap any UTF8 char (see documentation http://rasm.wikidot.com/syntax:data-structures )
- ability to remap any UTF8 char when using inline struct and parameter overload
- ability to ouput hexadecimal in strings (see documentation)
- bugfix segfault with self-recursive structure declaration
- Rasm MSDOS version is back ^_^
src/url: https://github.com/EdouardBERGE/rasm/re ... tag/v2.3.5 ;linked:
Message Publié : 01 Mai 2025, 18:33
v2.3.6: Beacon 2025
- new directive SUM16 to create 16-bits checksum (useful for manual Amsdos Header)
- new directive FREEQUOTES (when you are bothered with command line option)
Message Publié : 29 Juil 2025, 13:26
Rasm 2.3.8 - Beacon 2025 Latest
v2.3.7 is DEPRECATED, please update :)
- bugfix IX/IY patch with repeat
- ss/sb command line option does not force snapshot output
- new tag EXISTS for INCBIN directive (see documentation)
- removed IX/IY trick to avoid missing invalid opcodes
- prevent addressing mode usage as value with instructions that cannot do that
src/url: https://github.com/EdouardBERGE/rasm/re ... tag/v2.3.8 ;linked:
Message Publié : 10 Nov 2025, 22:28
Message(s) : 519
bim! Rasm POLARIS est sorti :)
https://github.com/EdouardBERGE/rasm/releases/tag/v3.0
pre-processing improvement to handle multi-param functions, better string merge
pre-processing refactoring/cleaning/speed
new math functions pow, lerp, clamp, fdim, fremain, fmin, fmax, fstep... (see online doc)
new functions CHECK, DELFILE, READFILE for EDSK directive
new ZX0 cruncher by Emmanuel Marty which is x30 faster than original implementation
SAVE on DSK is now using EDSK directive core and is able to update any kind of floppy
STR directive evolutions (allow bytes inside strings, hex output, but... see online doc)
simple banking is now supported when assembling to emulator RAM
enforce memory configuration when recalling a rombank set
added a warning for empty strings
bugfix intempestive error with OR and XOR directive
bugfix octal 0o prefix
better error messages
hundreds of new autotests
added Z80 simulator by superzazu for cruncher autotesting
documentation is up to date!
Message Publié : 08 Jan 2026, 09:28
Rasm 3.0.4 - Polaris Latest
- new tag SKIPHEADER for INCBIN directive
- empty quote warning now display source+line
- bugfix SNAPINIT and dynamic alloc + non crunched chunks
- bugfix alias export with original case + alias case with RASM symbol export
Rasm 3.0.3 - Polaris
- main engine optimisation
- check for existing label before creating a new var
- bugfix SKIP option when switch back from NOCODE section
- do not output ACE symbol file except with dedicated command line option
- do not output ACE symbol chunk in cartridge except with dedicated BUILDCPR directive option
- command line option for include path now accept space between option and path
- ability to set filename for snapshot or cartridge with their respective directive
- Visual C upgraded to 2026 for windows x64 binary
- documentation up to date
- new autotests
Rasm 3.0.2 - Polaris
- new math function FILEBYTE to read byte from a file
- bugfix save on DSK + overwrite
- bugfix save on DSK with other users
- bugfix save on DSK + overwrite on an almost full floppy
Rasm 3.0.1 - Polaris
- new directive REDEFINE_BRK to change BRK output
- more optimisations during initialisation
- more autotests and Z80 internal simulations
- trigger a proper error when trying to crunch more than 64K of data with LZSA (because it cant handle this)
- bugfix expression parsing with single minus sign between parenthesis
- bugfix dynamic crunch segment with ZX0B
url/src: https://github.com/EdouardBERGE/rasm/re ... tag/v3.0.4
Message Publié : 16 Fév 2026, 21:12
Rasm 3.0.7 - Polaris
- new directive ENUM
- new math function COUNTNOPS
- do not export regular proximity labels of breakpoints global labels as breakpoints (intempestive)
- ludicrous optimisation + fix uninitialised floating point usage in textbook case
Rasm 3.0.6 - Polaris
- ability to use variables in ram/rom/bank names
- bugfix SNAPINIT with snapshot not containing legacy memory chunk
- bugfix segfault with LD missing argument with directives GETTICK/GETNOP
Rasm 3.0.5 - Polaris
- INCBIN directive enhancements (see http://rasm.wikidot.com/keywords:import )
- better method to retrieve local alias case when root label is in another file
- bugfix rare memory leak with absurd syntax usage of SET/RES
