Nov 12 2010 New version ccz80 3.0.2:
* Use Microsoft .NET 4 Client Profile to reduce the requirements for the computer. * Add some optimizations for generated code.
ccz80 IDE and sprUtilCPC sprites editor for Amstrad CPC is also compiled to Microsoft .NET 4 Client Profile. Syntax files for editors adapted to ccz80 version 3.
la 2eme update pour ce mois de Janvier
Jan 22 2011 Improved setup utility: -Facilitate the implementation of ccz80 for different computers. Create shortcuts for all installed documentation. Compiler ccz80 version 3.1.0: -Allows you to specify constant values of type byte, word and string as an expression of constant operands. -Review and improvements to syntax check the source code.
Feb 2 2011 Improvements in ccz80 IDE: -New option Edit/Select block. -Improvements in the outcome of the option Format / Formatting assembler. -New button on Find/replace window to copy the marked matched lines to clipboard. -Fix in the replacement of text within a selection. -Initially mark all matches found in the Find/replace window. Compiler ccz80 version 3.1.1: -Fix for running applications indicated by the /post option when the path contains spaces. -Improved formatting of generated assembly code with /asm option.
Feb 3 2011 - New library function for Amstrad PCW. Also applies with some exceptions for Amstrad CPC in 6128 and Spectrum +3 CP/M Plus. - Added in setup utility the option to install the environment for Amstrad PCW using this new library.
Compiler ccz80 version 3.1.3 (Mar 4 2012): -Fixed the value returned by relational operators. -Allow positive and negative values at the displacement of the assembly instructions with indexed records. -Division by zero detection in expressions in ccz80 code and in expressions in assembler code. -Fixed character encoding of text files generated. -Allow constant string as second parameter in substract. -Alloc numeric constant as condicion of condicional operator. -Added label __begin_program at start of program. -Added new functions in standard.ccz80 library: absb, absw, sgnb, sgnw, min, max, sqrt, power, previousrand, signedword, endprogram. -Fixed functions btoh and wtoh in standard.ccz80 library. -Fixed functions cursor, key, finputc, finputs and eof in Amstrad CPC libraries. -Optimization of function copychr and improvement in function save in Amstrad CPC libraries.
